Will the mechanical O2 fix screw up the A/F ratio?
Old Aug 21, 2008 | 07:50 AM
icole's Avatar
NOt much more to say then the title. I am switching from a magnaflow HFC to a mil.spec 100 cell. Sean @ Ivey said I do not need a retune for the cat, but if I do a mechanical fix for the CEL I am worried that my car may run lean. Does the computer use the cat mounted O2 sensor to adjust the fuel mixture, or does it use a different sensor upstream?
Old Aug 21, 2008 | 07:53 AM
EvoBroMA's Avatar
noob!!!!!
haha. the secondary o2 sensor is only used to check cat efficiency. it will not effect A/F. some of us don't even run a secondary o2 sensor.
edit: The primary o2 sensor is located on the turbo outlet. thats why most people call this piece an "o2 housing"
Old Aug 21, 2008 | 07:59 AM
icole's Avatar
Thanks that is what I thought, but I wanted to be sure. I knew people ran with a resistor in place of the O2 sensor, but I thought it was possible they flashed the ECU to get the A/F right, and it is better safe then buying a new motor.
Old Aug 21, 2008 | 08:10 AM
EvoBroMA's Avatar
no prob! its better to ask and learn, then be sorry you screwed something up.
