great.....
Old Nov 5, 2008 | 12:24 PM
Anyevowilldo's Avatar
great.....
Ok so I've read up on evos here for a while now and made the plunge last nite on a 03 bby last nite I drove 12 hrs to get it got home and slept great and was very excited for this morning. I woke up and installes a temp boost gauge I had from my old wrx and I'm only boosting 12 psi no more no less like clockwork, I checked all the vacuum lines and the plumbing looks fine but......it had a hks filter kit with pipe and a cheap bov welded to the uicp vta at that, so first thing I did this morn was recirculate the bov to the intake pipe in the hole that was plugged bfore the turbo. That helped my idle dramatically as well as the hideous whine it made. Now my question is there's no tune no mbc so bfore I get the ix dv what else could cause the low boost? Can u adjust boost on the actuator or bov? Obviously the previous owner was clueless since his mods were cheap vta bov, tubular headers, and intake wit no tune.....car runs good and smooth just low boost please help.
Old Nov 5, 2008 | 12:26 PM
staatz's Avatar
Just get a mbc and turn it back up to 19psi.
Old Nov 5, 2008 | 12:32 PM
porsherules911's Avatar
Time for boost leak test.
Old Nov 5, 2008 | 12:37 PM
bluebanana23's Avatar
Get a boost controller. Sounds like the previous owner removed it causing you to run on wastegate pressure.
Old Nov 5, 2008 | 12:42 PM
Red_Evolution's Avatar
I believe either your stock boost solenoid is BAD... and that will automatically set your boost to 12 psi... (stock actuator pressure).... ORRRR your solenoid is GOOD... but the hoses are connected to the wrong nipples..
first try to change your hoses around.. see if thats it..
if that dont work then buy a MBC.. turn it up.. if that dont work.. then ur problem is elsewhere...
Old Nov 5, 2008 | 01:02 PM
Ok which nipples?and where's the boost solenoid?
Old Nov 5, 2008 | 01:18 PM
Elmo's_EVO_MR's Avatar
boost leak test then boost controller... but before check all vac lines
Old Nov 5, 2008 | 02:54 PM
Ok finally found the right terms to search for diagnosed the problem my vacuum lines are blue hence not oem so I need a mbc, thanks for the help everyone, I can't wait to post pics of my new baby
Old Nov 5, 2008 | 04:23 PM
andreww238's Avatar
yea 12 psi is very low...most likely your just running on wastegate pressure
Old Nov 6, 2008 | 08:48 AM
BBS's Avatar
BBS
Make sure you have the pill or orifice in the line that runs to your bcs. If its not there you won't hit factory boost levels.
Old Nov 6, 2008 | 08:52 AM
EvoDom's Avatar
this could be the problem. get a boost controller
Old Nov 6, 2008 | 10:40 AM
Peterr928's Avatar
Lots of people who buy used evos run into this problem. It usually happens when the previous owner pulls out all the aftermarket parts to sell the car and don't bother to hook the boost solenoid back up. get an MBC
Old Nov 9, 2008 | 11:39 AM
DOUGLAS's Avatar
I also drove 12 hours one way to pick up my BBY baby 2 months ago....It will forever be one of the better purchases I have ever and probably will ever make.....let see some pics
Old Nov 9, 2008 | 11:54 AM
ImJoey's Avatar
BBY is still my favorite evo color. I settled for black/black/SSL.
Old Nov 11, 2008 | 01:39 PM
linwoodm's Avatar
Check to see if there is a Forge WG, and check the spring
nobodyphil
80
Mar 16, 2011 07:35 PM
Atreyu_590
54
Sep 26, 2008 05:23 AM
spooch
Oct 10, 2007 07:02 PM
Itchy
May 21, 2007 03:33 PM
evilbada
45
Feb 11, 2006 12:12 PM
