Why is it.....
Old Nov 5, 2008 | 09:35 PM
RABYRAB's Avatar
Why is it.....
why is it the ECU will not kick any codes out yet the CEL is on???
Old Nov 6, 2008 | 06:23 AM
Chemwarrior's Avatar
What are you talking about? If the CEL is on you can use various techniques to read the code; OBD-II reader, tactrix cable.
Old Nov 6, 2008 | 06:50 AM
rcheung's Avatar
How did you know the ECU did not "kick out" any codes? What method did you use to try to get the codes?
Old Nov 6, 2008 | 06:53 AM
RABYRAB's Avatar
greddy code reader. It was giving me codes before now its not
Old Nov 6, 2008 | 07:49 AM
rcheung's Avatar
Try resetting the battery and see if the light comes back or use another code reader.
Old Nov 6, 2008 | 07:51 PM
RABYRAB's Avatar
it was reading all the codes before, i dont get it.
Old Nov 6, 2008 | 08:20 PM
EatSleepBoost's Avatar
way to vague posts.
Old Nov 6, 2008 | 08:47 PM
RABYRAB's Avatar
I had 3 codes and the cel is still on but now it doesnt read any codes.
Old Nov 6, 2008 | 08:52 PM
takeshi999's Avatar
reset the ecu by unpluging the battery for a few mins hit the brake a few times and plug it back it...might be some weird error in the communication.
Old Nov 6, 2008 | 09:02 PM
hksevoix's Avatar
Try using a obd2 scanner, it may just be your device that isn't functioning properly
Old Nov 7, 2008 | 12:41 PM
rcheung's Avatar
You keep getting the same repsonses over and over again. Have you tried resetting the battery and see if the codes came back or tried another OBD2 scanner? Forget about the greddy reader for now.
Old Nov 7, 2008 | 03:32 PM
RABYRAB's Avatar
k, will try the battery. but thats what i did, i replaced the battery.
