greddy cw shift knob moves
Old Dec 16, 2008 | 09:56 PM
N3VO's Avatar
so i put on the greddy cw shift knob not to long ago, i tightened it well onto the thread and then put the black sticker on it to make sure placement was perfect and then a couple days later i looked and it had moved, it was loose so i tightened it and now the sticker is off center,anyone else experience this before? lol
Old Dec 16, 2008 | 10:00 PM
Broxma's Avatar
Use a folded piece of aluminum foil in the knob to decrease the thread size then put it back on. The foil will fill in gaps and make it tighter and you can turn it wherever you want.
A toothpick also works but I prefer foil.
/brox
Old Dec 16, 2008 | 10:02 PM
Evoryder's Avatar
I don't know if it's the knob or sticker on mine lol ..it's tight
Old Dec 17, 2008 | 07:20 AM
N3VO's Avatar
alright ill try that out thanks
Old Dec 17, 2008 | 09:15 AM
JKD's Avatar
JKD
I've had the same thing happen several times. I end up taking it back off and restart putting it on. Do it a few times and you'll get it perfect.
Old Dec 17, 2008 | 09:19 AM
boostedtres's Avatar
had the same problem with mine, eventually it just was off center and i said forget it. then some how over time it loosened up gradually and i was able to tighten it little by little, and now its perfect. good luck
Old Dec 17, 2008 | 09:57 AM
mhchan218's Avatar
I used plumber's tape before screwing the Greddy CW on. now its tight as hell and the sticker is straight.
http://flasc.com/images/articles/teflon_tape.jpg
Old Dec 17, 2008 | 11:03 AM
hytek369's Avatar
+1 for foil.
Old Dec 17, 2008 | 04:24 PM
N3VO's Avatar
yea i tried teflon tape today but it was screwing on too tight to make it on center. it actually started to twist the shift boot covering so i just took the tape off and its back to normal uncentered lol
Old Dec 17, 2008 | 06:10 PM
Spish's Avatar
Originally Posted by mhchan218
i used plumber's tape before screwing the greddy cw on. Now its tight as hell and the sticker is straight.
+1
Old Dec 17, 2008 | 06:51 PM
MR White's Avatar
How does the CW knob feel? I am tempted to get one but not sure if it's going to make a difference.
Old Dec 17, 2008 | 07:49 PM
Spish's Avatar
The diff is that the greddy doesn't have stiching that eats your hand, and its heavy as a sum*****, works great.
Old Dec 18, 2008 | 01:43 PM
enVmyIX's Avatar
i have the same problem, i've learned to live with it
reboundicon
Mar 17, 2011 10:04 PM
Skott2k
Apr 3, 2009 07:19 AM
deegaw11
Mar 18, 2009 10:00 PM
atombomb33
May 14, 2007 09:09 AM
EVOTEXAS
Feb 26, 2005 01:28 AM
