Windows won't go down?
Old Jan 4, 2009 | 02:50 PM
RunRunRun's Avatar
I have a problem. My passenger side and two rear windows won't go down. They're not stuck, it feels like there is no power getting to them. I have no clue where to look. Please help!
Thanks.
Old Jan 4, 2009 | 02:51 PM
scorke's Avatar
Um.
have you checked the window lock?
/dodges
Scorke
Old Jan 4, 2009 | 02:52 PM
X91EVO's Avatar
Registered User
check fuses? switch connections
Old Jan 4, 2009 | 02:55 PM
evoracingstar's Avatar
i would have to say make sure ur window lock ant on! then i would check fuses for sure! gl
Alex Rodriguez's Avatar
Just remove the door panel , disconnect the window switch from the harness that goes to window regulator and test it.
if it goes up or down the motors are good the switch is bad.
Are u trying with the driver side one if so do that and if the motors work then you ds switch is no good
Old Jan 4, 2009 | 03:01 PM
wevo1985's Avatar
Originally Posted by scorke
Um.
/dodges
Scorke
+1. check this before you take anything apart!!!!!!
Old Jan 4, 2009 | 03:04 PM
wevo1985's Avatar
not the 1st thing i would do, check the easy things first. fuses, window lock switch. see if the other buttons work for the windows.
Old Jan 4, 2009 | 03:35 PM
RunRunRun's Avatar
The window locks are not on haha I've checked that. They won't work from the driver door or the door itself. I will check fuses and then I guess test the motors individually and let everyone know whats going on. Thank you guys!
Old Jan 4, 2009 | 06:12 PM
andreww238's Avatar
i agree
Old Jan 4, 2009 | 08:18 PM
MR_Evo_Rob's Avatar
Ok, i had a similar problem with my car a few months back except all my windows stop rolling up about an inch from the full closed position. took it to my buddy who is a master tech for mitsu here. after looking for a few minutes, figures out that a ground went bad on the inside of my car DIRECTLY to the left of the clutch pedal. has about 3-5 grounds under one bolt if i remember correctly. just find new grounds for those wires and you should be good as new if its the same problem.
Old Jan 4, 2009 | 11:25 PM
biggie5252's Avatar
If it's not the ground issue as posted above it's more than likely your driver's side switch panel or wiring in between.
Old Jan 5, 2009 | 05:06 AM
MR_Evo_Rob's Avatar
Yeah, i didn't think of that. Main Window Switches go out a lot(in fords and mazdas).
Old Jan 5, 2009 | 05:52 PM
Well, I say that because checking the window lock and fuses is the first step and is the most common ,so I assumed he did that already.
The op didnt say he checked the super easy stuff. Of course check the easy then move to the hard , but I gave him a run down on what to do so he should get an answer soon.
Old Jan 6, 2009 | 01:49 PM
EM1 to EVO's Avatar
Could be one of 3 things: Wiring connectors are loose or corroded, the main window switch is bad, or the ETACS-ECU is bad. I doubt all 3 motors went bad at once.
Old Jan 8, 2009 | 07:51 AM
JSC Speed's Avatar
Former Vendor
I am willing to bet the cause is a bad ground or fuse.
