swapping factory gauges for aftermarket ones???
Old Jan 31, 2009 | 03:30 PM
b00sted1's Avatar
I have been searching around on here all day and can't find anything! Does anyone know if you can swap the sport meter boost, oil temp, and volt gauges out for aftermarket ones? Obviously, you can, but I want to know if you can keep the OEM sport meter wiring and just swap the gauges. Anyone done this?
Old Jan 31, 2009 | 09:39 PM
EvoDom's Avatar
i dont think you would be able to unless what ever guage you did had the same hook up as the stock 3 gauges. And FYI the holes that those 3 guages are in (im guessing you have the set-up of the MR?) arent your standard 52mm, they are something like 46mm or w.e.
so just order 3 new guages and run them its not hard, becuase i dought any aftermarket guage will work with the stock guage connections.
Old Jan 31, 2009 | 09:47 PM
chaotichoax's Avatar
simply answer...no
you'd have to do some rewiring on the sports meter harness as the oil temp and volts have special pin connectors
as evodom mentioned the gauges are also I believe 42mm and the only aftermarket alternative that is close is a 45mm omori gauge
Old Jan 31, 2009 | 10:52 PM
b00sted1's Avatar
To clear up fitment due to gauge size, I plan on using a different bezel. As far as the wiring, I have no problems repinning the connectors, that's easy. What I am wondering is if the aftermarket gauges use different numbers of wires, sensors that don't cross over, or different inputs...as I would think that a digital vs. mechanical boost gauge would use a different set up. I hope I am clearing my question up as it evolves. If anyone has any more info based on this, I would love to hear it.
TIA,
Jeff
Old Jan 31, 2009 | 11:12 PM
I don't think anyone has successfully used the oem oil temp sensor with an aftermarket gauge
both gauges require a boost source so you may be able to use the boost tube and both gauges would need a ground and power for illumination
the meter kit harness has grounds/switched 12v sources/standard 12v sources
Old Feb 1, 2009 | 10:51 AM
b00sted1's Avatar
cool...this is the kind of info I'm looking for. Anyone have any more?
Old Feb 1, 2009 | 10:57 AM
Psquared's Avatar
http://store.42draftdesigns.com/Lanc...anel_p_14.html
This is the most close to stock gauge setup you are probably going to find. It will require some re-wiring, but it's simple.
Old Feb 1, 2009 | 11:36 AM
Aman's Avatar
u can also try Omori 45mm gauge . they will fit ur stock sport meter gauges plus they come in amber color and will match perfectly with ur interior lights. u can buy them at www.j-spectuning.com here is pic of the 45mm omori boost gauge modified to fit the stock lancer gauge in evo cluster.
Old Feb 1, 2009 | 11:55 AM
evo8426's Avatar
that looks really cool
Old Feb 1, 2009 | 12:10 PM
they won't fit unless you modify the bezel
Old Feb 1, 2009 | 02:59 PM
Aman's Avatar
hmm arent stock gauges 46mm .. ??? maybe i am worng . i tired to put a mechanical stock mitsu boost gauge in my cluster. i was having hard time doing it , that's why i ended up with a 45mm omori gauge. the thing is only .80 inch deep. it worked out like pretty easy. i know 1mm is not a big difference. but it can make a difference.
Old Feb 2, 2009 | 06:02 PM
j1's Avatar
j1
I wanted to replace my stock boost gauge with an AEM Truboost. Is the DIN bezel actually large enough to accomodate a 52mm gauge if you machine it? It seems like it might be too small.
Old Feb 2, 2009 | 06:08 PM
Aman's Avatar
52mm is going to be to big.
Old Feb 12, 2009 | 01:49 PM
MR2Racer28's Avatar
i have been thinking about doing it i just havent found the time.
MCPunk79
Jul 31, 2012 05:56 AM
lancealott
Apr 6, 2010 08:54 PM
06_RALLI///ART
Aug 26, 2008 07:02 PM
CatalystIX
Feb 10, 2008 02:53 PM
perversity
21
Oct 24, 2003 12:56 PM
