Side Spat
Old Mar 9, 2009 | 06:36 PM
mhchan218's Avatar
Side Spat
Just recently installed side spats since we had 1 warm day recently. Did I screw up? There are gaps towards the front and where the tape is. Its not a huge gap but wanted to know if anyone else had a close up pic of theirs. I've searched other pictures but they're not close enough to see. But from what I can tell it sits right up on the body. Thanks.
[/IMG]
Old Mar 10, 2009 | 06:50 PM
SICK9's Avatar
My passenger side did the same thing when I first put them on.
I took it off and moved the tape down a little and it formed right up to the body.
I would just take it off and remove tape, then reposition the tape lower and see if it helps.
Make sure you use fresh double sided tape and clean the car body area again before you reattach...
Or: you could heat it up with a hair dryer just a little [not too hot], and try and push it in some..
good luck.
Old Mar 11, 2009 | 09:53 AM
LancerEVOmann's Avatar
I have the same problem on mine I got from Rexpeed. I'll try taking it off and putting the tape lower. Derek @ Rexpeed told me to adjust the holes on the bottom of it to get a tighter fit. Haven't done that yet.
Old Mar 11, 2009 | 06:08 PM
mhchan218's Avatar
thanks guys, i will try as soon as it gets warmer again. i was too hasty and look where it got me.
Old Mar 12, 2009 | 04:53 PM
lghtngyello03's Avatar
You should always take your time man. Little crap like that makes you automatically think, oh this will take no time, lol. I hate it when I screw up stuff like that all because I'm in a rush.
I have been wanting to get these for my LY, and was wondering how they fit, and how the install went. Is there like holes on the backside or underside of them, that get screwed into the sideskirt factory screw holes?
I would try doing like Jamie (SICK9) said, and take them off and relocate the tape with fresh 3M double sided tape.
Post pics when you fix it, and let us know what you did to fix it man.
Old Mar 12, 2009 | 05:13 PM
SICK9's Avatar
Not sure about the ones he has, but I have the "HKS Kansai" side spats and they have holes on the underside that use the factory holes + the tape..
After I added the DAMD side skirt extensions, the screws go thru it and the side spats.
Let us know how the fix goes..
Old Mar 12, 2009 | 05:15 PM
tchouko's Avatar
have the same prob...doesn't fit perfectly for some reson
Old Mar 12, 2009 | 09:40 PM
Fast-Mover's Avatar
you need to use screws
Old Mar 14, 2009 | 03:49 PM
mhchan218's Avatar
I haven't fixed it yet but I will post pics when its done. the piece comes with the tape already on it and there are two holes which you can use the screws that are on the factory side skirts (underside).
Lesson learned: take your time and dont try to get things done on a tight schedule.
dboz
May 27, 2011 10:19 PM
elusiveGSR
Mar 1, 2011 08:34 AM
JaxRRevoX
Nov 7, 2010 05:48 AM
adammartini
Nov 17, 2009 08:38 PM
the_window
For Sale - Part Outs
22
Aug 14, 2008 10:36 AM
