Pulled my passenger side tire off.. What happened?? Pics..
Old May 10, 2009 | 04:55 PM
RedEcotecSS's Avatar
So I decided I was going to paint my calipers today because they were badly faded (along with everything else...). So I pull the front passenger tire off first. First off, I notice that there is a LOT of black tar looking stuff caked on the fender wells. It's THICK. I guess the previous owner didn't give a crap about it or something... So I grab the degreaser and start cleaning. I got most of it off but couldn't get it all...
Anyway, on to the topic, well, just check out these pictures.. What do you think happened here? It looks like the tire rubbed it really bad and it melted or something?? Any ideas??
Old May 10, 2009 | 05:02 PM
ak47po's Avatar
Major rubbing problem.What size wheels and tires you running?
Old May 10, 2009 | 05:05 PM
mountainturbo's Avatar
Mine is starting to do that, but it's because the fender liner is loose (missing some bolts) so the tire rubs at full lock. I need to fix it before it gets that bad!
Old May 10, 2009 | 05:12 PM
mullen's Avatar
any time you go 100+ the liner pushs back and rubs on the tire...common problem
Old May 10, 2009 | 05:26 PM
245/45/17 tire size. i was worried that it was something worse then a rubbing problem.. i'm not too concerned about rubbing. i'll whip some zip ties out but i think the damage is already done..
Old May 10, 2009 | 08:12 PM
jjm4life's Avatar
your tires are too tall. my fender liners are so mangled im debating just cutting them out
Old May 10, 2009 | 08:14 PM
Showbizz41's Avatar
Had the same thing happen to myself. tire rubbed when plastics were secured
Old May 10, 2009 | 08:16 PM
BTW: what is that radiator looking thing behind the fender? Didnt bother checking when I had the tire off and just thought I'd ask..
Old May 10, 2009 | 08:18 PM
hamx0r's Avatar
thats your oil cooler...
Old May 10, 2009 | 08:24 PM
Ah thanks. I'm still a noob when it comes to these cars...
On and side note, I've been having some power issues (sometimes my radio or whatever will cut out when i hit the breaks, turn signals, ect..) is there anything (wires or anything) around the area of this fender that could cause some electrical issues if rubbed or cut? Thanks for any info.
Old May 10, 2009 | 09:31 PM
Nasty Evolution's Avatar
^^^Not on that side.. the drivers side had the main engine harness running through it though.
Old May 11, 2009 | 05:31 AM
thanks i'll snoop around that area then.
Old May 11, 2009 | 05:34 AM
MHarvey1986's Avatar
you may also want to have you vacuum system checked - I had a 240sx (I know, completely different) that had the same problem..... PCV valve was the fix
Old May 11, 2009 | 06:26 AM
blownevo's Avatar
Yea it even happend to me...I got in on order, but it's taking a long *** time to come in.
Old May 11, 2009 | 06:28 AM
LI Pinky's Avatar
Same thing happened to my brothers SRT4...It's not to uncommon on for those black clips to come off and allowed tthose fender liners to rub more then normal
