Life or Death situation! Help!
Old May 17, 2009 | 05:25 PM
TheoryVIII's Avatar
I Need a part or my wife will take my life. I need a Tiny SRS connector located under the passenger B pillar connected to the seat belt mechanism. If I am not able to get this part from one of you guys i am going to have to buy the entire srs wire harness just for the $.30 piece. I have tried contacting several totaled evo owners and have asked to this part repeatedly. Someone help my inspections past due. If anyone can help I cant give much for it but I would greatly appreciate it. Heres the part I need
I need the connector and a few inches of the wire(yellow)
Old May 17, 2009 | 05:34 PM
StreetEvo's Avatar
so, umm, what exactly is wrong with that plug? And how did it pull out? I really don't recommend splicing a new plug onto the existing harness. Any splicing/soldering on those wires messes with the resistance of the circuit, which can lead to a "failure to deploy" of the pre-tensioner in that seat belt.
Old May 17, 2009 | 06:40 PM
Kracka's Avatar
Can you just remove the plug and hard-wire the connections together?
Old May 17, 2009 | 06:48 PM
TheoryVIII's Avatar
the extra wire is just a last resort i know possible repercussions of splicing the wires together. No actually there is a smaller plastic round piece that fits on the end of that connector and thats the actual piece that broke what this round piece does is from what i can see connect the two wires together inside the "socket" but its just easier to ask for the connector than all of that. Now If any gurus out there can tel me another way to make this work without that piece thats fine I just need the srs light to go off the seat belt is not in use ever.
Old May 17, 2009 | 06:52 PM
StreetEvo's Avatar
I can look to see if I have a spare laying around at my work tomorrow, but I really doubt I'll have one.
Old May 17, 2009 | 06:54 PM
derangedazn's Avatar
does it go away if you buckle the seatbelt?
Old May 17, 2009 | 07:19 PM
TheoryVIII's Avatar
Thanks! Also I don't know If this is a piece that can be found on a regular lancer not sure if it is evo specific
It does not. Probably for the better knowing me I would have it jerry rigged with the buckle in it at all times just out of frustration. Why what are you thinking?
Old May 17, 2009 | 07:22 PM
MRCole's Avatar
Wrong. If done right soldering adds no more resistance. The only way this case would be true is if you have a cold soldier joint or if you just twist the wires together and they oxidize will it mess with continuity.
EDIT: how much for the entire harness? $100+?
Old May 17, 2009 | 07:28 PM
TheoryVIII's Avatar
The possibility ran through my head but if you look in the pic of where the connection plugs into is actually into the seat belt mech. theres no wires i can connect to .
Old May 18, 2009 | 03:16 AM
AznEvoIX's Avatar
Jesus.
$0.30 cents and you have to pay $100.00 for a WHOLE harness!?!?!?!
Screw that man.
Sell the wife.
LOL. *Just joking* s(^_^)b
Best of luck to you buddy!
Old May 18, 2009 | 04:37 AM
Edi-no-son's Avatar
Sorry i'm not much help in this thread, but i'm don't understand why your wife will kill you if you dont get this 30c piece?? Lolz
So please explain (since I'm not understand what this little bit actually does...)
Old May 18, 2009 | 05:17 AM
TonyMS's Avatar
Cause he will have to spend a 100 and I know my wife would kill me
Old May 18, 2009 | 07:13 AM
Edi-no-son's Avatar
haha ok ok got the point now lolz
Well good luck finding it! lolz
Old May 18, 2009 | 11:57 AM
randomevo's Avatar
take out the srs light bulb, worked for me, passed inspection fine ;-)
unless they are checking those wires which i don't know why they would
Old May 18, 2009 | 12:55 PM
oneofakindtrini's Avatar
Can't you get someone to override the code or light for you?
