Evo VII Front clip..
Old Oct 5, 2003 | 08:54 AM
MalibuJack's Avatar
Ok, this may sound odd, and may be the wrong place to post.. But I'm looking to get a complete EVO VII front clip (Nose, Engine, wiring, etc..)
I would like to put the VII nose Bodywork on my VIII but the real reason is I want a complete donor drivetrain that I can build up over the winter.. with the ability to mock up my modifications.. Any ideas?
Old Oct 5, 2003 | 09:05 AM
zlancer's Avatar
its very hard to find newer front clips..evo's 4-5 are easy to get but 6-8 are extreamly hard.
http://www.flashoptions.com/product_...17&subcatID=42
that site usually comes across some evo clips...
just do a yahoo search for like "japan front clip" and you should find some links
Old Oct 5, 2003 | 09:13 AM
rogue's Avatar
do not buy anything from flash options. If you need reasons why not i will post up some info from one of the nissans boards.
Old Oct 5, 2003 | 11:45 AM
Celm's Avatar
Malibu
email me and ill hook you up with a guy of mine in japan
Old Oct 5, 2003 | 05:33 PM
xjapx's Avatar
i'd like to know why not to order from flash options. i was looking at the site about sr20det's and stuff.
Old Oct 5, 2003 | 06:34 PM
rogue's Avatar
as promised:
http://nissaninfiniticlub.com/forums...=flash+options
best thing to do is a search on that forum. There is alot of stuff.
for an SR > heavy throttle, phase2motortrend, project silvia, enjuku racing, and there is some place in manasas that allows you to pick out your engine. Trust me on this becareful where you get your engine from. I bought my SR for my previous car from a great seller and I got a great engine.
sorry if this went off topic but for anyone buying engine or high price parts, you get what you pay for, plus its used.
Old Oct 6, 2003 | 11:58 AM
xjapx's Avatar
thanks for the onfirmation man. whenever i decide to do the swap stuff after i get the car, i'll just probably end up going to libero or soemthing. but thanks for the info. i don't see it as going to far off topic. someone mentioned FO, so you gave them info on FO.
Old Oct 6, 2003 | 12:26 PM
jotan82's Avatar
planning a 6-speed conversion?
Old Oct 6, 2003 | 01:10 PM
MalibuJack's Avatar
No.. Just interested in the JDM Drivetrain.. I'm fairly certain that the 7's had the same transmission (more or less) as what we have.. What I really want is the ECU, harness, sheet metal, bumper, rebar, etc..
Old Oct 6, 2003 | 01:16 PM
Chris in HB's Avatar
Contact RMR - they converted a VII to VIII externally, so they might have the VII parts still. Also, they have a full VII dash and the ACD hardware - hence, you could have an VIII that looks like a VII with ACD (no AYC). Just a thought. I am sure it would be costly, but you'd be the only car like it.
Chris
Old Oct 6, 2003 | 01:23 PM
GPTourer's Avatar
Re: Evo VII Front clip..
I'm curious, why would you want to do this? If you aren't interested in the tranny swap, or any of the electronic diffs, why wouldn't you just get USDM VIII front clip from a local salvage yard? (Seems a bunch are popping up more and more). Is it because of cost? A half cut car won't have anything past the a-pillars, so why swap in an older motor that will need a different ECU, if you're going to build up the USDM 8 motor which is essentially the same? If you buy a back half EVO 7 they surely won't match. I can understand the bodywork part, but it seems like a lot to spend, just to get a hood, bumper and grill.
No knocking your project, just wondering what the goal is.
pinoyevo23
May 1, 2016 04:34 PM
Evo a Mula
Mar 16, 2010 02:30 PM
evo8jedi
Feb 7, 2010 01:30 PM
Death-Row
May 1, 2008 05:25 PM
ACCOLADE
Mar 28, 2004 10:50 AM
