taking out tranny on a 03 evo help!!!!!
Old Jan 7, 2010 | 09:38 PM
moses_4g63's Avatar
just tryin to gather some info, tips or references for removal of a tranny and transfer case on my 03 evo ! ! ! im an aircraft mechanic by trade so im def mechanically inclined just don t wanna go under the car and start to wing it lol any feed back would be great!!!
Old Jan 7, 2010 | 09:39 PM
Force-Fed Performance's Avatar
Have a couple friends handy and some pry bars
Dont forget to take the intermediate shaft out of the driver side when the axles are out or the T-case will not seperate from the trans
Take your time and its no big deal
Old Jan 7, 2010 | 09:42 PM
oneofakindracer's Avatar
if your doing it in the driveway with no lift make sure the car is really really high bc you hafta get the tranny out from under it plus the jack. also its a good idea to make 2 long studs to screw into the block to guide the tranny backk in this is not essential but helps alot. pm me if you need some help its not the easiest tranny removal of them all.
Old Jan 7, 2010 | 09:51 PM
JohnDoe1984's Avatar
What you need is the evomoto guide bookmarked if you don't already. It's all that you need to get the job done.
http://www.evomoto.com/tech_articles..._article_id=27
Even if you're not doing a clutch the steps for the tranny are all there.
Old Jan 7, 2010 | 10:26 PM
chaotichoax's Avatar
search for more... the evomoto guide is the best
closed...
