HID Question ! need help !
Old Feb 20, 2010 | 10:15 AM
GdotRegEvo9's Avatar
hey im in the process of installing HID lights. The Bumper and Headlights are off and i have an Evo 9 SE. Am i supposed to take the projector housing out ?? the HID ballast does not fit in the projector. thanks for your help.
Old Feb 20, 2010 | 10:32 AM
garcias2k's Avatar
The ballast mounts under the headlight or on the side somewhere. Do not remove or take apart the projector housing. Most all hid kits are plug in and play type. You should be able to put the hid bulb right into where the factory low beam bulb went without modification.
Old Feb 20, 2010 | 10:46 AM
Fixed !
Attached Thumbnails HID Question ! need help !-2010-02-20-13.36.45.jpg   HID Question ! need help !-2010-02-20-13.37.10.jpg   HID Question ! need help !-2010-02-20-13.37.00.jpg
Old Feb 20, 2010 | 10:54 AM
garcias2k's Avatar
When you take the hid bulb and place into the projector, does it sit flush? And is there a wire clip that wraps around the bulb to secure it to the back of the projector? What kind of hid kit is it and what type of bulbs did you remove?
Old Feb 20, 2010 | 10:57 AM
Found ok found the reason thanks !
Old Feb 20, 2010 | 11:03 AM
rgar's Avatar
From the pictures you posted. Your new bulbs come with a clear plastic casing that is there to protect them during shipping. you unscrew it and the top comes off, then you back the bottom off the wire. Then you plug the bulb in(don't touch the bulb).
Old Feb 20, 2010 | 11:05 AM
garcias2k's Avatar
As long as the hid kit you purchased is a 9006 kit, the bulb will seat into the projector just like the factory bulb. And just like rgar said, remove the plastic case that surrounds the bulb. I like to use latex gloves when I'm messing with hid bulbs.
Old Feb 20, 2010 | 11:15 AM
rgar's Avatar
Yeah... This thing is trash, and doesn't belong on your lights.
6spdlegend
13
Apr 10, 2017 12:45 PM
evoxboost
Evo X How Tos / Installations
Aug 13, 2015 04:37 AM
dbowdt
Lancer Troubleshooting
Mar 27, 2012 07:03 AM
lookitznite
Jul 19, 2011 03:25 PM
GraphiteEvo9
Jun 6, 2010 07:21 PM
