Hi flo cat install question
Old Mar 12, 2010 | 09:48 AM
pshooter's Avatar
Putting a HF cat (perrin) on my IX. Does the rear O2 sensor go before or after the cat? or does it make a difference?
The stock cat has it right in the middle and there is cat material at both ends?
Old Mar 12, 2010 | 09:49 AM
evo unknown's Avatar
you want the O2 sensor to be as far after the high flow cat as possible. That placement will decrease the chance of the CEL coming on.
Old Mar 12, 2010 | 09:50 AM
Genesis8's Avatar
I have mine after the cat.
Old Mar 15, 2010 | 09:56 AM
Steve_P's Avatar
after
Old Mar 15, 2010 | 09:57 AM
Foolproof's Avatar
Originally Posted by evo unknown
you want the o2 sensor to be as far after the high flow cat as possible. That placement will decrease the chance of the cel coming on.
+1
Old Mar 15, 2010 | 09:59 AM
c kim's Avatar
I'd put on a mechanical o2 fix on there just in case.
Old Mar 15, 2010 | 12:13 PM
Boostd4's Avatar
This^
I put a mechanical fix with my HFC and didn't have a single CEL in over 30K miles on my Evo 8.
Old Mar 15, 2010 | 12:17 PM
shh!! sleeping's Avatar
I would recommend getting rid of the high flow cat and just putting on a test pipe... I had the perrin high flow cat and it held back 33hp of my car and instead of running 11.8's i was running 12.1's. Test pipe it, you will be happier in the long run
Old Mar 15, 2010 | 12:25 PM
evocivicmarc88's Avatar
test pipe ftmfw.
Old Mar 15, 2010 | 06:41 PM
kane.s2k's Avatar
33whp is a lot of restriction! Sadly, I live in a state where it wouldn't be a good idea to do that and the class that I want to race in requires a cat.
Old Mar 15, 2010 | 07:25 PM
McLaren F1 2003's Avatar
a mil.spec 100 cell cat wouldnt have held back 33hp haha
Old Mar 16, 2010 | 03:43 AM
MR Turco's Avatar
or just shut off the rear o2.
Old Mar 16, 2010 | 08:09 AM
Boostd4's Avatar
Wise words.
The wonders of ECU flashing
Old Mar 16, 2010 | 08:16 AM
evo72man's Avatar
When I ran a HFC I used a O2 cell delete and you will not throw any codes. Ask any shop or tuner for a cell delete.
