Heat/Ac control lights, where can i buy these????
Like the title says ive looked everywhere, online, advance auto, napa, and autozone and i cant find the little dash lights to light up the ac and heater controls
+1 on the dealership, even at the stealership they're not expensive I mean how much can you charge for a small bulb?!?!?!? or you can try http://www.mitsubishiparts.net
The HVAC bulbs from superbrightLEDs.com I BELIEVE are a 73, only thing that takes the T1.5 are the cluster lights, the HVAC bulbs can be pulled right from their socket, as they are a wedge bulb... so no "wire a bunch of ****" as you put it... I'd get the 360 degree SMD LEDs, to get the light more even.
Just a correction for *Bassicfun.* They are actually type 74. I purchased 74-xHP3 in red from superbrightleds and I'm very pleased. The Bulbs found in your ignition ring, HVAC, cig lighter, ashtray, Optional 3 guage cluster and Odometer are type 74.
