My evo feels like a lancer
Old Apr 24, 2010 | 12:47 AM
Dube's Avatar
Got a new exedy clutch installed a couple days ago. Installed a perrin intake yesterday. Noticed that it has become extremely slow now, even will my foot on the pedal it doesnt seem fast at all as it was before. Not sure if its the intake, boost, or a hose that needs to be connected somewhere.. I think one of my hoses isn't connected anywhere, not sure where to put it.. Ill have to get more info on what that hose is I just drove 10 hours so ill get back on that. Im pissed, just one problem after another.
Old Apr 24, 2010 | 12:51 AM
ASPerformance's Avatar
Do you have a boost gauge? My first guess is that you have a massive boost leak or maybe your oem boost solenoid got disconnected. A clutch job is a pretty big job so who knows you probably have an intercooler pipe not even tightened up
Old Apr 24, 2010 | 05:20 AM
Berts24's Avatar
^ this, most likely a boost leak
Old Apr 24, 2010 | 05:25 AM
Bobster22388's Avatar
If you just put an intake on your car, your going to have to get a retune also as your moving more air past the MAF now and throwing off your A/F ratio.
Old Apr 24, 2010 | 06:02 AM
06redrocket's Avatar
thats not true. You wouldnt need a tune by simply replacing the intake . Anyway sounds like you have a boost leak . Like stated above before you do anything do a boost leak test. Gl
Old Apr 24, 2010 | 06:12 AM
Foolproof's Avatar
Yeah I am going to vote boost leak also. I put my full exhaust, intake, mbc on and I didnt have any issue driving for a few days before I got tuned.
Old Apr 24, 2010 | 06:15 AM
EvolNinja's Avatar
Now why would the OP wants to get on boost right after install of a new clutch? Peddle to the metal is "full boost" = life of the clutch goes down unless Exedy don't require break-in for their clutches.
Old Apr 24, 2010 | 06:18 AM
Berts24's Avatar
^ good call!
Old Apr 24, 2010 | 06:36 AM
metalsaber's Avatar
Do a boost leak test. Most likely there is a problem with one of your couplers or vacuum lines.
Old Apr 24, 2010 | 06:46 AM
Dube's Avatar
Maybe that hose that my friend disconnected was important.. Hmm.. Thanks guys ill look into it.
Also, if I cant do the boost leak test. Is it bad if I let it leak if I dont put it in boost? Ill need to break in my clutch before I do that.
Old Apr 24, 2010 | 08:23 AM
max4rw's Avatar
its not good, and your car will continue to feel like a "lancer" DO A BOOST LEAK TEST! its not hard search the how to's on how to make a tester! its only like 10 bucks from home depot or lows for the parts. good luck
Old Apr 24, 2010 | 08:26 AM
erald01's Avatar
do a boost leak test, check you oem boost sleneoids and make sure you didnt disconnet them by mistake
Old Apr 24, 2010 | 08:29 AM
Genesis8's Avatar
+1
Originally Posted by bobster22388
if you just put an intake on your car, your going to have to get a retune also as your moving more air past the maf now and throwing off your a/f ratio.
Old Apr 24, 2010 | 01:16 PM
Dube's Avatar
Found out it was the vacuum valve cover vent hose not being properly zip tied down. Leave it to my friends to mess something up huh. Thanks for all the feedback everyone.
Old Apr 24, 2010 | 08:39 PM
GG_9_SE's Avatar
Have you had a tune since installing the intake?
