100LL mix?
Old Jun 9, 2010 | 08:14 PM
gallas's Avatar
100LL mix?
Ok well the thought crossed my mind, i have a unlimited supply of jet A 100LL at my disposal with my job. is their any way i can do a mix of the 100LL with regular 92 oc pump gas to raise my octane rating at all? or will my car just run like crap
Old Jun 9, 2010 | 08:25 PM
Paul Walkin's Avatar
The lead is so heavy and the octane is not that much better then say 93 that I experimented with.
I didn't see any gains, and the car actually logged slower.
Old Jun 13, 2010 | 02:55 PM
gallas's Avatar
I was actually reffering to mixing 100LL with 92 oc pump gas to see if i could at least get the minimum 94 oc.
Old Jun 13, 2010 | 05:08 PM
AznEvoIX's Avatar
You should try it.
But if it blows up, its your fault. =)
Old Jun 13, 2010 | 06:19 PM
heel2toe's Avatar
From what I have read jet fuel is a no go. They are typically of higher octane however the lead will reduce the lifespan of your o2 sensors. Also note that the fuel has other special chemicals in it which help with the higher altitudes which arent necessarily good for a car.
Old Jun 14, 2010 | 06:25 AM
I mixed some 100LL with 93 in an attempt to "spike" the fuel.
It added enough lead to slow the burn (and reduce power) but not enough octane to effectively raise boost or timing.
Old Jun 14, 2010 | 06:45 PM
aeroweenie's Avatar
100LL is gasoline, not jet fuel.
Old Jun 14, 2010 | 07:13 PM
heavens turbo's Avatar
avgas is some dirty stuff compared to refined gas. you might as well add diesel to your tank. i would just find some c-16 if i were you.
Old Jun 14, 2010 | 09:24 PM
gallas's Avatar
ya i just figured i would ask, just im around it all day and can get it easy. woulda made things really easy on me for fixing my crapy 92 oc reading up here in alaska
Benja
15
Feb 11, 2011 04:59 PM
Lancerguy'03
North Texas Evo Club (NTEC)
Sep 17, 2010 11:49 PM
06mr775
Apr 27, 2010 02:54 PM
vegasevo9
Aug 23, 2008 06:46 PM
ArchieBabes
12
Oct 17, 2004 07:31 PM
