Evo 6 : SRS Fault codes help
Hi Guys
I took my car , Evo 6, into Mitsi as the SRS and ABS lights have come on.
Can some please help me interpret the codes and how to fix it ?
Mitsi could give me a price because they said they would have to invistage further which normlly means $$$$$$$$$$ .
MUT3 codes:
12 - FL Sensor open
63 - SRS ECU fail
26 - Speed sensor
41 - TPS Open
22 - D-AB SQ TRBL2
32- Condens Voltage Low
45 - SRSDIAG Unit
Is the codes related ? The guy at Mitsi said that the ABS wheel sensor could be dirty or may have stone jamed. Where is the wheel sensor and how do i clean it ?
Lastly is there a fuse for the SRS or ABS ?
I am hoping that i can fix to save $$$$$
Regards
Gavin
MUT3 codes:
12 - FL Sensor open
63 - SRS ECU fail
26 - Speed sensor
41 - TPS Open
22 - D-AB SQ TRBL2
45 - SRSDIAG Unit
Regards
Gavin
Sometimes it is worth the money to have someone diagnose the problem right or fix it right. Try disconnect the batt. neg. cable for 1 min. and see if the warning lights comes back on with the same codes. GL.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
