starter fuse
Old Jun 25, 2010 | 08:49 AM
Evo9"Miss Rose"'s Avatar
starter fuse
Besides the Fuse on the Positive cable is there anyother FUSE for the starter i can loook at?!?!? MY Car doesnt Turn over, but was able to push the car and pop the clutch it started got it home, next morning no cranking over can anyone care to CHIME in on my problem?!?!?!
Old Jun 25, 2010 | 09:11 AM
gsrboi80's Avatar
Check the lead to the starter solenoid it's a thin wire connection may have broken
Old Jun 25, 2010 | 09:18 AM
ill check up on that thaanks for the info.... another thing is i had a jumpstarter on it this morning thinking my battery was dead, turned it over couple time and the cables got super HOT and smoke was coming from the negative post cable
Old Jun 25, 2010 | 09:41 AM
gsrboi80's Avatar
Sounds like bad grounding there man. Check them all thoroughly
Or you had the jumper cables backward which I doubt. Opps
Old Jun 25, 2010 | 11:31 AM
ill check out the grounds aswell!! hahaha naw they were on correct thanks again
Old Jun 25, 2010 | 11:44 AM
RoadSpike's Avatar
You consider your starter could just be dead?
Sounds like the relay is working on the starter so the little wire is fine.
If its smoking the battery cables it probably just done and needs to be replaced.
Old Jun 25, 2010 | 11:49 AM
20gmr's Avatar
just pull the starter off and have a buddy run you up to advance and have them test it. From my experience things getting hott tells me you hgave mechanical resistance somewhere. Either in the starter,engine,or engine accessories (alternator,power steering pump...)
Old Jun 25, 2010 | 01:16 PM
lets hope its not a dead starter*crossingfingers =/... regardless ill be inspecting everything thanks for the QUICK TIPS much appreciated
Old Jun 25, 2010 | 01:28 PM
Berts24's Avatar
+1 on testing the starter
Old Jun 25, 2010 | 11:49 PM
goldenEvo's Avatar
I think the starter is drawing too much amps. Can you turn the motor easy with your hands. If so, the starter took a dive. GL.
Old Jun 26, 2010 | 05:38 AM
ch53avitech's Avatar
I was going to suggest replacing your muffler bearings but testing the starter sounds like a better idea. GL!
boostedspra
May 16, 2013 11:19 AM
Lil red '03
Lancer Troubleshooting
Dec 28, 2012 10:02 PM
12secDD
May 22, 2012 11:37 AM
aspensvt16
Feb 25, 2008 02:50 AM
nubi4life
Nov 3, 2007 02:57 PM
