Gauge Fitment Issue
Gauge Fitment Issue
I purcahsed 3 Defi gauges and the Center Bezel from Gruppe-S. I was doing a dry fit of the gauges when I encounted an fitting issue with the right gauge. Looks like the back of my gauge is hitting where the radio was mounted (pic below). I wanted to know if anyone has had this problem?
There were a few posts about a year or so ago about this issue. The metal bracket which obstructs the right side gauge is part of the radio support bracket, which you won't need if you are using the new three gauge panel. If you look closely, you'll see that you can remove the screws which hold the bracket in place. I took the bracket out, and trimmed it with a Dremel cut off wheel. If I remember correctly, a few members of this forum trimmed it without removing it. I took it out first because I didn't wand metal filings, etc in my dash or carpet. Good luck.
