Official - Evo Towing Thread
Old Oct 10, 2010 | 04:32 PM
  #31
*nr*brent's Avatar
Originally Posted by Keoki
That's pretty damn crazy looking!
looks awesome... this is my new screen saver lol
Old Oct 11, 2010 | 04:11 AM
  #32
savaho's Avatar
Originally Posted by blkmkIII
does anyone know where i can get a hitch for my evo.... us bumper, rear rebar ect still in place
U-haul. Ask for a regular lancer (i.e. 2004) hitch but be prepared to make a cutout in your bumper cover for the hitch to pass through. If you're pretty crafty, I'm sure you can find a way to make it work and be stealth when not in use.
Old Oct 11, 2010 | 06:48 AM
  #33
clc3667's Avatar
We have plenty of braking power to tow with that's for sure lol.
Old Oct 11, 2010 | 09:44 AM
  #34
evo8426's Avatar
a guy that i used to see driving around town like 6 years ago would tow his motorcycle behind him
Old Oct 11, 2010 | 09:56 AM
  #35
06RS's Avatar
I've seen a few Evo's setup to tow wheels/tires.
The best I've seen had the tow hitch welded onto the rear crash beam. He cut a hole through the bumper behind where the licence plate would normally be. I believe that JMFab made the bracket.
Old Oct 11, 2010 | 11:40 AM
  #36
Bassicfun's Avatar
Has anyone used the uhaul one? pictures of its fitment on the evo? thanks.
Old Oct 12, 2010 | 08:30 AM
  #37
asrdave's Avatar
towing a waverunner with an evo is awesome do you ever get any problems when you r rear gets in the water tho?
Old Oct 12, 2010 | 09:41 AM
  #38
cs82685's Avatar
You didn't even bother to read the first post did you...
Originally Posted by savaho
Before I get inundated with all the questions here's the info on the hitch:
2004 Mistu Lancer hitch from u-haul installed for $305 - no modifications whatsoever. The hitch part that bolts up to the crash beam is not used since there is no crash beam on my ride with the JDM bumper. The part not bolted up is used to aid in supporting the tongue weight but if you keep it under 150lbs you should be fine. As it is, the tongue weight on my jetski hitch is about 40-60 lbs.
Old Oct 12, 2010 | 10:34 AM
  #39
Bassicfun's Avatar
Originally Posted by cs82685
You didn\'t even bother to read the first post did you...
WOW pretty brutal for the one word I did not put in my post... STOCK evo, meaning USDM bumper cover, and full crash beam/bumper in tact. Basically just as bkm had asked... Thanks in advance, and my apologizes to the OP?
Old Oct 13, 2010 | 04:45 PM
  #40
EVO8STI's Avatar
i pulled my evo up a hill with my 85 cavalier that has a very bad slipping disk. it made my day
Old Oct 13, 2010 | 05:30 PM
  #41
cumminsracer14's Avatar
I think its awsome to see an evo towing
Old Jan 27, 2012 | 06:41 PM
  #42
savaho's Avatar
bump
Old Jan 27, 2012 | 06:58 PM
  #43
HiPsiCanadaGuy's Avatar
that first pic is awesome. I couldn't imagine towing anything with my car.
Old Jan 28, 2012 | 08:07 AM
  #44
GTijoejoe's Avatar
Originally Posted by EVO8STI
that cant be good on the suspension on the red evo
Exactly, it was never intended for that type of axle load.
Just about any vehicle can tow 1000lbs. Motorcycles, jetskis, wheels/tires should be no problem, I love the first post
Anything higher than 1000lbs on a vehicle which does not have a tow rating is increasing your risk and could potentially be dangerous. Keep in mind towing is just not on braking, engine/transmission cooling, axle loads, and frame strength are also key factors. Vehicles which tow normally are tested in death valley on a specific downhill road for extreme conditions.
A note of caution, if you do however find yourself to get into an accident while towing, there is a possibility (pretty good one to) your insurance will not cover it as your vehicle does not have a tow rating, which means it was never tested for it by gov't regulations, which might deem it hazardous/wreckless.
Old Jan 28, 2012 | 08:14 AM
  #45
wtf_is_a_evo's Avatar
wow i seen one pic i cant find it with the rear end of the evo in the water droping something off.
