What Mods Should i Do next?
Old Oct 7, 2010 | 08:57 AM
Ghost1t's Avatar
Hi
I became a proud owner of a Evo IX MR 06 ,4 months ago
Now iam no tech guy and i dont pretend to be one so here it goes.....
So far , its all good
I bougth it with :
Greddy exhaust
HKS BOV
HKS Intake
walbro fuel pump
unknown injectors
some trashy turbo manifold
and of course its stock turbo
Since then i have done to it is
Change the manifold to the stock one - port it & ceramic coat added
Hallman boost controller
Fix the vacuum lines
Mechanic (Norman Evo) did something to the stock wastegate
Aem Wideband added
Greddy turbo timer added - for safety and coolness
My Transfer case is whinning , not so loud , iam afraid that i may be broken , but iam going to do change of fluids next to see if it stops , if it doesent ............anyways.
after all that was installed
A tune was done and boost was increased
330hp @ 25 boost that was the avg . it something showed up as 342hp
So far i was happy with the result , but of course more work has to be done.
Anyways dont know what should i do next my goal is to reach 400hp
i was thinking i could reach that by putting new intercooler and ic pipes which are currently stock and cams but i dont know if that is JUST it.
Leave your feedback! thanks!
P.S. - I removed the wing
Old Oct 7, 2010 | 09:16 AM
vtecownedyou's Avatar
get some volks and susp to compromise with your engine works
Old Oct 7, 2010 | 10:23 AM
4g63Moon's Avatar
uicp doesn't do **** for ur car. Get the licp and intercooler for sure to hold more boost and quicker spool along with 02 housing. Cams will def give you more power/torque if tuned right. 400hp and a evo 9 is easy.
Old Oct 7, 2010 | 10:30 AM
Jrah2987's Avatar
Veteran: Air Force
Take a look at the injectors to see if it has the info written on them. Depending on what they are, maybe E85 would be a good step since you have a pump and a tuner available. I would also get a down pipe & test pipe if it hasn't already been done.
Be careful about the whining t-case. If it needs a new ring & pinion it can get very pricey very quick.
Good luck!
Old Oct 7, 2010 | 11:24 AM
JuniorIA's Avatar
Intercooler kit and e85.
For kicks and giggles get some GSC s2 cams!
