can a turbo warp on the cool side?
Old Oct 8, 2010 | 09:04 AM
EVO8STI's Avatar
Question can a turbo warp on the cool side?
i replaced my turbo a few months back with a oem. when i removed it i noticed it has red silicone around the coolside going into the licp. i thought why in the hell would someone do this? anyway i replaced my turbo and cleaned the pipe of the silicone and installed the shim/gasket. worked fine but while under boost my turbo sounded like a diesel , not so much like a boost leak or escaping air so i figured it was the turbo doing what it does. but the last few weeks it got really loud and i knew it was a boost leak. i found it at the pipe were the silicone was and it was pushing air so hard it whistled very loudly at about 20psi. nothing appears to be broke/cracked/loose or out of normal. all i can figure is the turbo is warped or the pipe is warped? ideas? sorry for the book but the more details the better.
Old Oct 8, 2010 | 09:21 AM
TeStUdO's Avatar
You used a new gasket between the turbo and LICP, right? Try tightening it and then check to see if the flange is warped on the LICP or turbo with a straight edge and feeler gauge.
Old Oct 13, 2010 | 08:26 AM
asrdave's Avatar
straight edge is your best friend when in doubt silicone is a good friend to have
Old Oct 13, 2010 | 04:40 PM
EVO8STI's Avatar
i hate to but i think i just gonna put silicone back on it.
Old Oct 13, 2010 | 07:15 PM
asrdave's Avatar
sometimes there is no other choice man, just a light layer will do
wowzers
Dec 15, 2014 12:41 PM
gobigny
Apr 16, 2014 10:09 AM
Ted B
Feb 17, 2010 08:52 PM
Oki Panoki
Driving Techniques
26
Oct 16, 2008 09:19 PM
xtnct
May 17, 2004 08:55 AM
