balance shaft eliminator
Old Oct 21, 2010 | 12:28 PM
EvoJoeIX's Avatar
is it a good idea to eliminate the balance shaft on a stock motor? im about to do my timing belt and figured why im in there i could take care of it. anyone else do this on a stock block? what are the advantages and disadvantages of doing this
Old Oct 21, 2010 | 12:37 PM
sobo's Avatar
I'd also like to know this.
Old Oct 21, 2010 | 12:39 PM
EVO8emUp's Avatar
Advantage, less rotational weight, never have to worry about the B belt breaking and getting caught up in the A belt.
As far as disadvantages.. I don't know the answer.
Old Oct 21, 2010 | 12:42 PM
Bobster22388's Avatar
Only disadvantage I can see would be having to pay for whole engine to be taken out just to do this.
Old Oct 21, 2010 | 12:46 PM
EVO8emUp's Avatar
I've never done one, but I bet it could be done by unbolting mounts and dropping one side down a bit.
Old Oct 21, 2010 | 12:57 PM
awdboosted's Avatar
Disadvantages:
- More vibration is felt but not made.
- Some bolts will start to back out. Ex: Oil filter and Alternator Bolts
- Oil pressure is kick up. This isn't bad but it puts a lot of oil in the head and the oil can't drain fast enough.. Solution is Kiggly's HLA Kiggly HLA
Beside that… I can’t really think of anything off the top of my head. Besides it's a PITA to install!!
Old Oct 21, 2010 | 01:05 PM
4RETECH's Avatar
Yeah, the hardest part would probably be getting the block off bearings installed while the engine is in the car. But again, I have never done one myself. I'm looking into the AMS kit.
Old Oct 21, 2010 | 01:12 PM
mithrandir7533's Avatar
You will need to rotate the bearing 180 degrees for the eliminated shaft to block the oil passage. I'm not sure if this can be accomplished with the engine still in the car. It really simplifies a timing belt installation with the pulley for the counterbalance shaft eliminated.
Old Oct 21, 2010 | 03:22 PM
EvoJoeIX's Avatar
oh wow, i thought it was an easy install considering its like 4 parts in the kit. ill just keep mine. haha
Old Oct 21, 2010 | 03:34 PM
*nr*brent's Avatar
Im def considering this as Im about to build my spare engine. are the gains worth the vibration??? is my only worry.
Old Oct 21, 2010 | 03:39 PM
wizzo 8's Avatar
Also curious
Old Oct 21, 2010 | 04:48 PM
Murf's Avatar
Yes it can be done with the engine in the car. Myself and a couple of friends did it to mine. IT IS A HUGE PITA, but possible. We removed oil pan, and front cover assy. Took proper sized impact socket with adapt. and one good shot knocked out the bearings. Putting in takes a very steady hand, and good aim...Over all worth it in the long run just to avoide breaking the B-belt and trashing the engine.
Old Nov 21, 2010 | 09:57 PM
honda-guy's Avatar
i have the motor out right now and getting ready to install Gates timing belt and balance shaft belt.
now i'm thinking about going with AMS Race Balance shaft eliminator, but i'm worry that the stock ECU wont like the additional vibration. i don't want put it in and find out that i have to go stand alone ecu later.
Old Nov 22, 2010 | 12:42 AM
EvoJoeIX's Avatar
I wouldn't even run a balance shaft eliminator unless you have a built/balanced engine....
Old Nov 22, 2010 | 03:23 AM
honda-guy's Avatar
not a built engine but the car will be on track more than street.
