My tachometer is going crazy! help please
Old Oct 24, 2010 | 03:38 PM
evo4life400's Avatar
hey everyone so i go to get my car detailed the other day and when i come to pick the car up the guy said that my tachometer wasn't working. this happened to me once last year but i parked the car for a few hours and it started working again. Now it won't work...it jumps around when i hit the brakes and the gas sparratically but most of the time it just sits at 0.
it cost me a 100 to have it diagnosed at mitsubishi and they said its the cluster itself that needs to be replaced. everything is working but the tach and my green light indicator for low beams.
someone help!
thanks
Old Oct 24, 2010 | 03:44 PM
wreckless969's Avatar
Pull the cluster and see if a trace is burned up or something.
Old Oct 24, 2010 | 04:12 PM
my father and i pulled the cluster and everything looked good...i almost feel like its a loose sensor underneath the car because when i hit the brakes hard or give it extra gas the sensor starts working
Old Oct 24, 2010 | 04:18 PM
What I would recommend is if you got an evo buddy in the area, sway clusters for a minute and see whats what.
Old Oct 24, 2010 | 04:26 PM
xbeckk's Avatar
if it was something loose at a sensor or something the check engine light would come on.
Old Oct 24, 2010 | 04:29 PM
Really? It has a pin out from the ecu, how does the ecu read it?
Old Oct 24, 2010 | 04:33 PM
they wouldnt have hit something near the ecu when cleaning it right? the ecu is covered underneath the passenger side floor right?
Old Oct 24, 2010 | 04:34 PM
Yeah its like behind the glove box, I'd check it. Couldn't hurt.
Old Oct 24, 2010 | 04:40 PM
there is a brown wire with little blue dots on it that isnt connected to anything
Old Oct 24, 2010 | 04:50 PM
http://roadraceengineering.com/evo/t...-ecuwiring.htm
Old Oct 24, 2010 | 04:59 PM
the wire for the tach seems to be fine but there is a brown wire branching off of it that isnt attached to anything. this has to be the problem! i dont know what the brown wire is for though
Old Oct 24, 2010 | 07:01 PM
mithrandir7533's Avatar
Check and make sure the tach gear is installed correctly. Its on the top of the transmission just under where the shifter cables are. If it's not it all the way the gear could be slipping in and out.
Old Oct 24, 2010 | 08:36 PM
i think i found the problem! there was a brown wire sliced into my tach wire going into the ECU...it was loose from maybe the previous owner installing a tach gauge...i think it was hitting metal or something because i started the car up and the tach was working fine. i will try again tomorrow to see if it wasn't coincidence
Angeloj-Miranda
Feb 9, 2015 01:35 AM
Marcus Lim
Sep 2, 2014 11:27 PM
Brad676
Aug 13, 2014 10:10 PM
ralliartation
Dec 1, 2011 06:28 PM
actafool2f
16
Dec 8, 2006 08:43 AM
