mbc, ebc, 3port
Old Nov 3, 2010 | 08:11 PM
volcano's Avatar
mbc, ebc, 3port
I am currently considering some type of boost controller for a 2006 evo mr, but after speaking to two tuners and reading several posts on evo m, I am confused about the benefits and disadvantages of a mbc, ebc, or a "3port".
The posts on evom seem to indicate that an ebc is harder to tune, but once tuned correctly, it does not need adjustments. The posts also indicate that the mbc is easier to tune, but may need adjustments based on weather. The tuners i spoke to claimed that the mbc is both easier to tune and does not require any adjustments afterwards.
So, to anyone that truly understands these (not hearsay or just repeating what you have seen on a posts) help me understand what are the pro's and con's for the ebc versus mbc. And also what is the difference between an ebc and a "3port".
Thanks
Old Nov 3, 2010 | 09:47 PM
Tfresh's Avatar
When people comment on how easy it is i guess its that persons definition of easy. I had a Greddy profec on my 951 which it was nice but a pain to set up. I later switched to a hallman and loved that and it held boost rock solid even in drastic temperature changes.
Old Nov 3, 2010 | 09:49 PM
doc29's Avatar
cold weather cranks up boost alittle...mbc has to be turned down so as not to overboost, and back up when it gets warm...ebc auto adjust but more expensive and more to go complex in design (more parts more can go wrong)...either way works...just what your comfortable with
Old Nov 3, 2010 | 10:11 PM
yellowevo82's Avatar
STM installed a hallman pro rx on my car, was skeptical at first about it cause i had a turbosmart mbc once n it was horrible jumped boost levels alot but i havent gone out to fix my hallman once yet and the temp has been 20 at night n 65 in the day.. If you need a hallman i have a pro rx for sale ..
Old Nov 4, 2010 | 05:59 AM
black95tt's Avatar
I have an AEM 3 port solenoid that is controlled by the AEM ECU. I can tell you first hand that it absolutely needs retuned for weather changes, and if you don't know what you are doing, it can be a major PITA to get it right. If I were you, I'd stick with a manual.
Conceptually, there really is no difference between the "3 port solenoids" and the EBC's. They are both computer controlled solenoid valves that control boost. When someone mentions a "3 port" they are usually referring to the valve itself that will be controlled with an engine ECU. The EBC's are basically an all in one deal where the controller controls the valve. The EBC's IMO are easier to set up of the two. But again, I'd go with a manual.
Old Nov 4, 2010 | 06:06 AM
Kracka's Avatar
I recommend a MBC for the 8/9. They're simple, cheap, and effective. The only reason I'd suggest a 3-port is if you want to run map-switching with different boost levels.
Old Nov 4, 2010 | 10:34 AM
TTsumibishi's Avatar
MBC unless you want to get a little more advanced.
Old Nov 4, 2010 | 01:10 PM
silverevo05's Avatar
Do you have pics installed?
i.e. If I get pulled over is it visible?
Old Nov 4, 2010 | 02:03 PM
HFA_Ultima's Avatar
My tuner recommended a mbc, I had already ordered my grimmspeed boost solenoid but he told me to buy a mbc.
Old Nov 4, 2010 | 02:12 PM
EvoJoeIX's Avatar
why would that matter? ive never been asked by a cop about how my evo controls boost
Old Nov 4, 2010 | 02:40 PM
Raptord's Avatar
MBC would be noticeable, not a 3-port though.
I'm loving my Grimmspeed 3-port, I have exactly the boost curve I want and the ECU can adjust WGDC based on IAC, so once you get it dialed in you don't need to touch it anymore.
That being said, it does take more work than an MBC to tune. Can't comment on an EBC as I've never had one.
Old Nov 4, 2010 | 02:58 PM
detroit pistins's Avatar
MBC = Easy to install, cheaper, but you will have to adjust it whenever the air density changes.
EBC = not familiar with thier installation ease, lil more expensive (depends on the model/brand), but it will help you spool faster as the pressure solenoid actuates based on the preset pressure signal. Unlike the mbc where a slight signal could apply a force to the MBC spring and leak some air effecting ur wga.
Overall, I think they all need to be adjusted due to the weather condition changes, however, i was told that the new HKS unit has a feature in which it helps u compensate for the density variation.
http://www.hksusa.com/categories/?id=1085
ps. I am running an MBC.
Old Nov 4, 2010 | 03:20 PM
EvoJoeIX's Avatar
theres 2 different types of MBC's. the bleed type and the ones with the ball and spring. if you get a quality mbc with the ball and spring it wont leak and you will spool just as a ebc
Old Nov 4, 2010 | 04:37 PM
have to admit that iam not familiar with the bleed type! how does it deliver the signal to the wga all at once or doe sit ramp it up?
ex. if i set it up at 24psi, would the wga see a 24psi signal all at once, or would the "bleeding" mbc ramp up?
Old Nov 4, 2010 | 04:38 PM
Thanks alot for the pm, lots of great info that are somewhat over my head
ps. u should probably share the info u sent me on here.
