I should've kept the wing...Hydroplaned?! on the highway
Old Nov 6, 2010 | 11:02 AM
  #31
dtrackstar's Avatar
Originally Posted by joeystacoshack
Yeah man the solution to this is quite simple. Water+ speed='s hydro planing.
But the wing joke was funny.
Not trying to get on you but if you're gonna drive a car like this like that you need to learn how to really drive. I'm guessing if you don't know about hydroplaning, even at low speeds in water, you don't know much about driving. You're lucky you didn't wreck your car.
Second hint that you need to take some time to learn how to drive was that you hit the brake when turning.
Also lifting the throttle can also act like hitting the brake if done too aggressively. Check out what this guy did in what should of been a routine situation...
http://www.youtube.com/watch?v=YgXieZTHqq8
Do yourself a favor, not being hard on ya, at least read some articles on driving and watch some you tube videos.
Here's a good one to get you started....
http://howkartswork.com/?p=428
Happy motoring.....
Thanks for the advice and the positive feedback. I agree, my 1st reaction should not have been to press on the brakes, but I didn't slam on them either. The car was out of my lane almost immediately, basically once it went sideways I was out of my lane and thats when I counter-steered and pressed on the brakes. To give an idea of how fast it happened...the car was over 45 degrees sideways as I left lane 3 to get into lane 2. The only smart thing I did was let off the brake as I was entering lane 1 where it started straightening out.
Originally Posted by atxMR
Driving 80-90 mph on a 3 lane highway in the rain isn't unheard of really. However, neither is hitting the break when you begin to hydroplane. If the OP were a bit more of an experienced driver in most situations he would have most likely skimmed over the water and never left his lane. Keep in mind that the same thing that affords you all of that traction in the dry conditions makes you more prone to hydroplaning...large contact surface. Granted, the awd does help keep your car planted, but it's not going to be a fix-all...you still need to DRIVE the car.
Thanks for agreeing that 80-90 when it rains isn't completely unheard of. But like I said earlier, it just happened so fast, I don't think it would've been humanly possible to keep it the same lane. The car went sideways so quick.
Originally Posted by Earthen
Here are some ways to prevent or lower your risk.
Maintain proper tire pressure
1/3 less of the posted speed
Maintain good tire tread
ALL TIRES WILL HYDROPLANE AT CERTAIN SPEED.
Be safe.
Thank you!!!
Originally Posted by ODUB
sombody already beat me to it, but yeah, hitting the brake was the wrong thing to do. you're lucky you didn't make it worse. the problem was the water, your tires, and the speed. just because you've got all seasons, doesn't mean it's safe to go that fast when it's pouring. if the road conditions change, and the you hit a pocket of deep water, that's your ***. you need to slow down, and learn to drive.
Agreed, brake was wrong thing to do. Learn how to drive...I ended up forward 2 lanes over not in a ditch, so I did something right. Not perfect driving but not bad either.
Old Nov 6, 2010 | 11:10 AM
  #32
evoboi005's Avatar
Thank you!!!
and if you would have ran someone off the road and killed them... still good? not to bad of driving ? if your not smart enough to drive slower in the rain esp if there is standing water on the road please dont drive ...i would be ashamed to post about it much less tell anyone if my car changed lanes period in the rain
Old Nov 6, 2010 | 11:15 AM
  #33
SpecialNeeds's Avatar
well, live and learn, as a teen I crashed my car a few times, learned the hard way when not to hit the brakes. in my twenties I started driving slower after each year passed. Now? i drive 55 on the highways always. jk. but glad you didnt get hurt. hyrdoplaning is scary.
Old Nov 6, 2010 | 11:19 AM
  #34
dtrackstar's Avatar
I don't see it necessary for you to write insulting my intelligence. It was obviously a bad choice on my part. I admitted that. The point of this thread was to find out what exactly caused it.
Thanks for your feedback
Old Nov 6, 2010 | 11:21 AM
  #35
dtrackstar's Avatar
SpecialNeeds....exactly! thanks
Old Nov 6, 2010 | 12:05 PM
  #36
nothere's Avatar
first thing you would have learned about driving on wet roads in hpde would have been to find the dry line. iow driving in your lane would have put you in ruts and standing water. Driving out of the ruts, lets say a foot or two off center would likely put one set of wheels on the hump and dryer line, but also with dripped oil on it.
since you were blowing the speed limit anyway you might as well blown off the stay in your lane law and driven on a dryer line. since that line likely has oil on it ... not so smart either.
Old Nov 6, 2010 | 12:10 PM
  #37
delongedoug's Avatar
It's your driving, not the car.
Old Nov 6, 2010 | 05:22 PM
  #38
dtrackstar's Avatar
Speed limit is 70 for the record. Regardless even going 70 with rainy conditions you can still get a ticket, I believe.
Delongedoug...yes I was going too fast. But like other guys have mentioned, they've done it before in autocross or the highway. Yes I was going too fast. But If I was in a heavier car, I don't think that would've happened.
Who knows though. Everyone is okay. I've learned from this and hopefully others reading it will learn from it too.
Old Nov 6, 2010 | 07:52 PM
  #39
TommiM's Avatar
Originally Posted by snowfish
You lucked out! Stepping on the brake should've sent you in a spin. You should've let go of the gas, counter steered and waited for the car to get back in control.
Maybe it seemed like it was going to one side but it really wasn't? Maybe the car was under control all the time?
ya I think he got lucky doing that manuever. awd+acd saved him that time.
Old Nov 6, 2010 | 08:45 PM
  #40
novem's Avatar
Try going to a large empty parking space, or a open dirt track. Set some visual markers or get some cones and start learning the limits of your car in wet and dry conditions. Usually modulating
The gas pedal not brake, will move car out of the corner with more control. Take up SCCA or a rally club! But I believe everyone should know the limits of their car.
P.S. It'd friggen fun!
N
Old Nov 7, 2010 | 08:45 AM
  #41
dtrackstar's Avatar
^ when I have time next season, I will. Thanks for the advice
Old Nov 7, 2010 | 12:22 PM
  #42
GTijoejoe's Avatar
N
I agree
Understanding your vehicle is best, but it is also hard to in all types of conditions.
hydroplaining occurs because the tires don't have the ability to push the water out of the way based on vehicle speed or volume of water so the tires ride on top of it like a surf board. In this condition throttle on/off brake etc will have less of a reaction because the car's balance (acceleration) is relatively even.... allowing the vehicle to decel under its own friction etc. is best to regain traction
In the case of that lotus, he was accelerating putting more down force on the rear wheels for traction, he snaps off the throttle and some of that force % will transfer up front causing the light rear end to overstear.
Classes teaching on/off throttle, driving dynamics and vehicle loading is very informative and educational for FWD, RWD and AWD applications specifically, I highly rec. these classes to driving enthusiasts.
In general, you should always be smooth in your motions, steering, braking, throttle will upset the car the least.
Old Nov 7, 2010 | 04:59 PM
  #43
sirsol's Avatar
What size tires are you running? Hydroplaning is rather difficult to do, and usually comes to having bad condition tires or just very poorely designed tires. Also, check your tires pressure. Too much or too little can effect how well the water removal passages on your tires work, so you may unintentional be lowering the efficiency of your tires.
Old Nov 7, 2010 | 05:15 PM
  #44
Wickedwhite8's Avatar
Glad your ok dude. Haven't seen you in a long time.
Old Nov 8, 2010 | 09:39 AM
  #45
snowfish's Avatar
The Lotus video is irrelevant. They drive VERY differently than our cars. Mid engine, rwd is totally different than AWD. I own a MRS and if you try to save a spin on a MRS it's totally different than say a RWD car or a AWD.
