buschur exhuast with titec 02
Ok, after hours putting on the 02.. I am not replacing it with a buschur one, however the burshur dp isn't made for a donut gasket where the 02 housing is made for one. so, right now im running gasket cut-out paper. I don't know if it's leaking or will leak in the future, but I'm thinking I might need to get a titec dp.
Also, i have a titec midpipe sitting at home, and a buschur one installed with an ebay muffler. I want to get a different muffler eventually but I need to know which ones fit because both midepipes are different sizes and the titec has a bend at the end of it.
I want to stick with the set up i have now, but replace the muffler with a name brand one. Buschur has the magnaflow and bullet options which I don't like.
what do you guys think?
the downpipe is fine without the gasket since it was designed to fit that way. the lip of the o2 housing goes down inside of the downpipe and seals pretty well and will not be a problem. both catbacks are different size? go with the one that is 3" diameter
