Multiple relays on one circut?
Old Dec 9, 2010 | 09:22 PM
crazy_ugly_coyo's Avatar
So Im in the process of building a custom wire harness for my race car. I was going over the factory diagram and noticed they had two relays in parallel for the fuel pump. Why is this, and do I need to do the same for my harness? If it makes a difference Im running a Walbro 255
Old Dec 10, 2010 | 07:04 AM
Heres a diagram of what Im talking about
Old Dec 10, 2010 | 12:17 PM
Routybouty's Avatar
Those are in series. I would guess for safety, the first is on when the ign is on and the second is ecu controlled. You could technically ditch the first one. I'm not sure what the third one does, maybe some type of primer.
Old Dec 11, 2010 | 12:35 PM
Phantom EVO's Avatar
You only need one relay for the pump. I believe that is a safety factor if something happens to the engine function the fuel pump shuts down. In your case for a race car you will need a shut off switch in the back that will kill all the electronic systems. If you relocate the battery to the trunk it is easier to run the switched power with 18ga wire and put the relay in the back near the pump and reduce the distance of the 10ga power wire to the pump.
sigumarapus
Sep 7, 2016 07:57 AM
AreSTG
Feb 15, 2015 12:22 PM
lancer10
Jan 31, 2012 04:47 PM
ralliartN20
Jun 7, 2008 06:34 PM
spyderx
Mar 13, 2005 11:10 AM
