evo 4 problems
Old Dec 24, 2010 | 02:17 AM
bluey180's Avatar
evo 4 problems
hi i'm new here , i've had my evo 4 for 3 years and its starting to play up . it runs lumpy at idle almost cutting out sometimes . everyone i spoke to said it would be the maf sensor so i got one and changed it this morning but the problem is still there , i've checked all the vacuum pipes but they seem to be ok . any suggestions would be most appreciated
Old Dec 24, 2010 | 02:12 PM
djikonatx's Avatar
I would start with a good boost leak. then i would take the throttle body of and sensors and clean it all completely with throttle body cleaner.make sure you mark the tps to line it back up right..then i would clean up the maf .make sure your plugs and spark plugs are ok
Old Dec 26, 2010 | 09:38 AM
bluey180's Avatar
thanx for that , will try all of that asap
Old Dec 26, 2010 | 09:41 AM
raulthode's Avatar
Clean up the Idle speed control motor.....could have filled with crud...if not replace.
Then use evoscan to reset the idle speed.
