JDM/USDM Carbon fiber rear crash beam
Hey guys, I've been bothered by the oem 17LBS crash beam & decided it was a good excuse to order the JDM rear bumper.
After alot of research on this beam it is clear it serves more of a purpose then a "crash beam", it is also a pretty critical hard point in the rear of our evos. That said, I've developed a carbon fiber crash beam that is designed to be stronger and alot lighter then the oem rear "beam", here are some pics of the foam in which I will layup the carbon fiber around with aluminum inserts, I am considering doing more of these for those who may be interested. I'll keep posting pics with progress and the final product shortly. Tell me what you think so far.
Thanks,
Blake
Thanks,
Blake
That a cool idea....great fresh thinking! I may sound dumb with this, but is a carbon fiber beam stronger that steel, you know crush "resistant"??
Good question! With the foam being the inner structure surrounded by the carbon fiber, given that it is "sandwiched" by the carbon fiber on all four sides, it is naturally a great "crush" structure as any car would hope to have.
Good idea by using a lite weight material and filling it with a "cushion". The only problem I may see is the price associated with CF. What about using aluminum instead of CF? Have you looked at the cost difference in the material itself and also the process to mold/create the outter enclosure between the two? Not trashing your idea by any means, just trying to think of all possible options.
CF has high tensile strength, and is very light weight, but I don't think it will do much in the area of absorbing impact. Tensile strength can be described as ability to withstand stretching...which both carbon fiber and steel posses. CF is composed of interlocking filaments of carbon atoms so it is very stong against stretching. However, steel has toughness that CF doesnt have. Toughness being the ability to withstand impact without breaking. Hit steel with a hammer and it dents...hit it hard enough and you may puncture the steel's structure. Take a hammer to CF and there will be no denting, it will just break apart like plastic. So for rigidity it may help, but for impact protection, I would have to say it won't do much....I'm theorizing here, so in practice I may be wrong
http://www.dowautomotive.com/products/impaxx/300.htm
Also if cost is permitting a layer of kevlar can add a bit of strength.
The "Crash Beam" is only a USDM thing, as insurance companies require it so they can pay less when it come to minor bumper accidents (less then 5mph). Its not a "safety" thing and is not gonna save your life or car in any accident above 5mph.
And since JDM and other markets DONT have it, I doubt it is a "critical hard point" as you say.
Jay the fact that the JDM market doesn't have one does not mean anything. Overseas car manufacturers do not have the same FMVSS200 safety standards that we have in the US. The engineering and development that goes on behind the scenes in the US is quite impressive in regards to occupant and bystandard safety. Although it was developed to help keep the costs down to both the insurance companies as well as consumers, safety was still a driver when NHTSA introduced the need for this requirement. 201U for instance is an interior occupant safety standard that takes many scenarios into consideration as far as rollover, unbelted occupants, etc. that is heavily developed in the US but not installed on cars that are exported.
Guess you didnt do enough research, as the JDM EVOs have NO crash beam.
Even his Foam core clearly shows its a modified version of the USDM crash beam in the same picture. He must have seen the same posts of the modded rear crash beam that fits a JDM bumper, and built of that.
Should give him the benefit of the doubt.
