IX MR SE vs IX SE - slightly different than every other thread on this topic
Old Feb 28, 2011 | 12:36 PM
LanEvo9MR's Avatar
what about e-brake cover?
Old Feb 28, 2011 | 12:38 PM
kdubb03's Avatar
FWIW, on the IX gears 1-4 are almost identical on the 5-speed and the 6-speed. If you wish you had a 6-speed, just pretend you have one. [/quote]
Just dont pretend reverse is 6th gear tho.
Old Feb 28, 2011 | 12:48 PM
BlackSE's Avatar
Yea i think the MR also has a Momo hand brake. If its not Momo its def different than the SE.
Old Feb 28, 2011 | 12:51 PM
nightwalker's Avatar
I don't get it. Converting to "SE spec" or "MR SE spec" doesn't make the car any faster or worth more.
But whatever floats your boat.
Old Feb 28, 2011 | 01:20 PM
EricLee7481's Avatar
To me, it's not the matter of posing my car as a MR when it's actually not, I'm more doing it so I can have the better options (IMO), i.e. the Bilstein/brake cooling guides that didn't come on my car.
Eric
Old Feb 28, 2011 | 01:34 PM
njboy's Avatar
It's the gap between 4 and 5 that's annoying on winding 50mph back roads.
Old Feb 28, 2011 | 01:41 PM
deeman101's Avatar
Originally Posted by njboy
I think for daily backroad driving the MR 6 speed is the better transmission. I have also heard that it is less clunky to shift. Keep your 6 speed I wish I had one.
I guess it feels smoother to shift than the 5 speeds I've tried (03 evo and 06 evo SE) but the throws are LONG and there is no proper shortshift available other than in house from WORKS. And theres probably way more shifting than you're expecting. In 6th at 3k I'm only going 70ish.
I think the gearing is different though. A lot of drag guys need to go into 4th and the ones that go faster than 110ish need to shift into 5th. Above all its a weaker transmission. Even the shep rebuilt one (which costs $$$ compared to a 5spd rebuild) will handle 450wtq on the high end.
Old Feb 28, 2011 | 01:43 PM
deeman101's Avatar
Eric
What are these brake cooling guides you guys are talking about? Is it the channel like things on the undertray?
Old Feb 28, 2011 | 01:46 PM
FJF's Avatar
FJF
At 50mph on a winding road I'm in 3rd, maybe 4th if the winding backroad isn't all that winding. I don't think my Evo ever saw 5th below highway speeds. No reason for it.
Old Feb 28, 2011 | 01:53 PM
Ryan.Kauz's Avatar
Thanks for the correction, I didn't know what they were officially called. I'm trying to find the most cost effective brake cooling ducts/guides to put on the car. I heard the stock ones are pretty easy to break off, and the AMS one is pretty pricey. Do you know of any other kinds?
Eric
Why nobody has pointed you to the BINARY brake ducting is beyond me...... VERY cost effective and a quality product.
Including buying 10' of tubing from racerparts it was about $200 total investment (plus $0.30 in zip ties)
http://www.binaryeng.com/products%20...e%20ducts.html
Old Feb 28, 2011 | 01:55 PM
FJF's Avatar
FJF
It's a clandestant conspiracy.
https://www.evolutionm.net/forums/dr...ix-evo-mr.html
Old Feb 28, 2011 | 06:21 PM
Thanks for the site. I've actually came across it a while back, but wasn't able to find the link again. I'll be sure to look into this one as this looks pretty promising!
Eric
Old Feb 28, 2011 | 07:20 PM
1QYK9's Avatar
Both have aluminum hoods and trunk lids.
Old Feb 28, 2011 | 07:52 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
You don't have to get it
I just wanted to confirm the differences.
Old Feb 28, 2011 | 10:15 PM
da_yo's Avatar
What about the passenger side CF dash? Is that MR only?
