Some Chase Bays Product Development Input needed! (Brake lines)
Old Mar 11, 2011 | 11:18 AM
ChaseBays's Avatar
I'll keep this short and to the point. We're in the development stages of 10+ Chase Bays products for the EVO chassis. One thing we are stumped on is proportioning valve placement. We could put it near the e-brake, under the dash, by the shifter, under the radio, by the fusebox on the bottom side of the side....anywhere around there. Just post your ideas, and where YOU would want it if you purchased our kit. We can always make 2 or 3 options.
Visual help...
The Proportioning valve. Note the adjustment knob...
Old Mar 11, 2011 | 06:39 PM
airbrush1's Avatar
I would be fine with placement anywhere as long as its easy to access if need be
Old Mar 11, 2011 | 06:42 PM
milford's Avatar
and the point of changing the stock brake proportioning is....
Old Mar 11, 2011 | 06:55 PM
dabeast's Avatar
+1
Old Mar 11, 2011 | 07:17 PM
ihockey1's Avatar
im guessing prop valve relocation for a wire tuck/cleaner engine bay
Old Mar 11, 2011 | 08:27 PM
SmurfZilla's Avatar
This
Old Mar 12, 2011 | 12:10 AM
nightwalker's Avatar
Will it make my car faster? stop better?
Old Mar 12, 2011 | 12:54 AM
ChaseBays's Avatar
Also for ABS delete. Yes, your car will be faster with all those ABS related items gone. 40 or 50 lbs if I had to guess from handling it.
Old Mar 12, 2011 | 02:23 PM
revvin9k's Avatar
I can't wait for this kit......all your kits are just top notch....
Old Mar 15, 2011 | 06:40 PM
Guerillah's Avatar
I've been waiting for this. All my honda buddies run your harnesses, they are TOP NOTCH. Can't wait to see pics
BTW, I say put it under the dash but still accessible without too much trouble. It should be hidden so people won't start turning the knob and possibly killing you in the process.
Old Mar 16, 2011 | 06:34 AM
boosted_EJ1's Avatar
Besides the delete of the ABS the main reason for it is because of a booster less master cylinder. You can fine tune your brakes to stop close to the same as when you had a booster.
Revobasher
Sep 26, 2011 03:58 PM
big block ix
Mar 20, 2011 09:49 PM
big block ix
Nov 14, 2010 08:17 PM
burnings
Oct 25, 2009 12:58 AM
def1
Oct 25, 2008 02:38 PM
