New Full Blown 70mm cast TB
#32
#39
Doesn't look like there is quite enough to port the manifold to a true 70mm. I'm gonna have to just try to smooth the transition as best I can. I think I'm gonna do that after testing it with just the adapter. I would be curious to see what the gains would be for both situations.
#40
You guys that bought this I'm wondering if you have installed it yet and what solutions you came up with for the EGR lines and the UICP. I am using the stock UICP and I don't want some cheap rigged looking coupler or anything. Obviously the Samco coupler I'm using isn't gonna cut it. I wonder if the EGR lines need to be pre throttle plate like on the stock throttle body or of you could tap into another line on the manifold. Thanks for any help.
