Very weird idle! (with video) PLEASE HELP!!!
Old Oct 22, 2011 | 01:32 PM
  #151
19.5PSI's Avatar
GREAT NEWS!!!!!!!!
i fixed my problem. the culprit was the EGR vacumm solendoid. took it out, put a new one in and right away the car sounded better. let it idle for 10 minutes and it sounds great.
it's a pain in the **** to get to but it can totally be done. took me roughly 45 minutes to do. got it all from the top of the car. you can see it but you can't see the bolt. you have to pretty much find the bold by feel and do it that way. 2 10mm bolts. disconnect 3 vacuum hose and a wiring harness. goddam im pretty happy right now.
for anyone still having that problem, check your EGR solenoid.
Old Oct 22, 2011 | 07:39 PM
  #152
C130flyer's Avatar
Originally Posted by 19.5PSI
GREAT NEWS!!!!!!!!
looks like I was right
Go me!!!! lol
Old Oct 22, 2011 | 08:28 PM
  #153
19.5PSI's Avatar
yeah good call.
i sorta had a feeling that it was but because of the location and cost of the solenoid, i wanted to try something easier and cheaper. im happy now...i get to drive my car again......after replacing the brakes of course.
Go me!!!! lol
Old Oct 24, 2011 | 07:08 PM
  #154
617APEXCT9A's Avatar
I've been following this thread for a while now because ! had the same symptom describe in the title "Very weird idle!" I pick up the part form the dealer and I finally had a chance to replace my EGR vacuum solenoid after work. I took my normal route home and the weird idle would happen just before i get home, but after today my idle is perfect it did not drop in rpm and the car runs perfect.
Old Oct 25, 2011 | 06:44 AM
  #155
C130flyer's Avatar
And my fixes justa keep ona rollin' !!!!!!!!!
Go me, Go me, Go me.......
Seriously though, I literally have about 15 hours of trouble shooting this problem to find the fix LOL
I'm so glad that it's a common fix that everyone can benefit from. I don't feel like it was a waste of time now.
Old Nov 4, 2011 | 05:57 PM
  #156
svt_lightning01's Avatar
Did you have a cel this last time when it was the egr solenoid? Im in the same boat right now and I have no cel I have an egr block off plate on the way hoping it fixes my woes. If it is the egr solenoid blocking off the valve would solve the issue correct?
Old Nov 5, 2011 | 09:19 AM
  #157
rhd-jon's Avatar
just bought a new egr valve from mitsubishi i'll change it out when the car comes out of the shop this week
Old Nov 7, 2011 | 06:29 PM
  #158
BBY_GSR's Avatar
Hey, would you mind writing up a little on this? Perhaps, you can include some pictures. My Evo has been parked in the driveway for quite some time now.
Just recently, the idle got worse and the idle became erratic. Now, the idle doesn't fluctuate as quickly (like a cammed out Evo), but it fluctuates slower and the car would start revving up to about 4k RPM and drop continuously.
Old Nov 7, 2011 | 07:52 PM
  #159
rhd-jon's Avatar
My advice read this thread check out a few things along the way. Iac/egr ur plugs try trouble shooting everything and anything u know. I'll post up the resolts as to what happens. Btw did u get any CEL like p0300 or p0401 ?
Old Nov 7, 2011 | 09:13 PM
  #160
BBY_GSR's Avatar
Thanks, rhd-jon.
I had a CEL for a while and one day, it disappeared. I was going to get the car checked out eventually. I still don't have a CEL.
Old Nov 12, 2011 | 11:53 AM
  #161
rhd-jon's Avatar
Changed my egr and im still having the same issue
Old Nov 14, 2011 | 10:24 AM
  #162
WolfsFang's Avatar
guess ill join this thread seeing how it started to sound like i had cams after the dealer changed my timing belt. Seems the erg valve is giving alot of people trouble so ill look into that.
Old Nov 14, 2011 | 11:23 AM
  #163
Scofflaw's Avatar
Figured I'd join the thread, since I'm also having idle issues. My AFR will be proper while the car is warming up, but once it's up to temp, the idle will drop down a bit, and AFR will go really lean, approx 22, then after a few secs of stumbling it'll rev up a bit and go to 12.
I changed my plugs, did the EGR bypass, cleaned my MAF, cleaned the ICV, nothing worked I'm suspecting maybe the ICV is broken (I'm going to check the connector with a multimeter this weekend), but my brother is telling me it's the tune.
I'll take a video this week.
Old Nov 14, 2011 | 02:40 PM
  #164
rhd-jon's Avatar
Could be that u need a tune.
Yesterday on my way to Ct to see a homie and 20 mins into the ride
my cell went on lucky that i found a autozone to check the cell. It also
happen again in Ct lol p0300 random misfire. I just orderd some new
spark plug wires from mitsubishi car has 85,000 and have the same wires
since day 1. Hopefully that helps if not i'll just wait till i go tune it.
Old Nov 14, 2011 | 03:23 PM
  #165
WolfsFang's Avatar
before i took my car to the dealer my car idled fine, when i got it back today it started to idle rough. It still hovers at 900rpm when im sitting but just sounds loopy and the smell from the exhaust dosent smell normal. All i have is a Catback and injen lower intercooler/intake piping.
Here is a video of how it sounds, would sound sexy if their wasent a problem involved.
http://www.youtube.com/watch?v=mMpSJq1CXDw
