reverse trigger wire
Old May 19, 2011 | 09:19 PM
wazzelby's Avatar
So I finally installed a double din head unit and a rear view camera. Problem is that I don't know where to source the reverse trigger wire to switch on the video for the rear view camera when I put it in reverse.. Anyone ever installed one of these on a Evo 9? I assumed it would be straight forward, I didn't know I needed some type of reverse trigger wire from the car.
Any help is very appreciated!!!
Old Jul 1, 2012 | 10:05 AM
NocturnalEVO's Avatar
bump
Old Jul 1, 2012 | 01:48 PM
AWDBus's Avatar
The reverse switch is on the transmission its self.
Old Jul 1, 2012 | 02:16 PM
1d10t's Avatar
Used for the reverse lights
Old Jul 1, 2012 | 11:15 PM
Marcac's Avatar
Should be a brown wire in the driver's side kick panel harness that goes to the rear of the car.
Old Jul 5, 2012 | 02:57 AM
jameelrose's Avatar
you can tap into the tail light harness just before the bulb
Old Jul 11, 2012 | 11:38 AM
dizaryl's Avatar
You should post this in the audio forum, but your getting good feedback. Also consider putting a pushbutton in parallel with your reverse lights so you can look behind you instead of thru a huge spoiler.
Old Jul 11, 2012 | 03:17 PM
hatesposers's Avatar
This is correct, it's a brown wire in the driver's kick pannel and it's positive switched. (it goes hot when reverse is engaged)
Old Jul 11, 2012 | 03:18 PM
Correct, but make sure you diode isolate it from the brown reverse light, or every time you press that button, your reverse lights would come on.
Old Jul 22, 2012 | 04:42 PM
dizaryl's Avatar
Nah, it's the ultimate brake check. J/K I forgot that part.
aduke05
10
Apr 26, 2020 10:31 PM
johnnyboii1219
Lancer How Tos / Installations
Sep 21, 2015 03:57 AM
Ibrahim Nabil
Jul 30, 2015 06:21 PM
VisG
14
Dec 15, 2014 06:20 AM
Jzarz313
Feb 16, 2012 10:52 PM
