curiosity... anyone running a dual set up
I am new to the community and driving an 04 gsr coming over from Bmw's I'm still learning. I am thinking of running a double tune on a toggle switch. One for e85 and one for 91. Anyone doing this? My current set up is full exhaust, intake, cam gears, perrin intercooler, burchur upper pipe, 272 cams, hallman boost controller, ported polished head, end blow off valve. Running 27 psi on 91 and want a little more. Anyone have a dual setup? Is it bad for the motor to run a dual set up? Thanks
buddy of mine uses it and loves it. Your going to need bigger injectors and a fuel pump. Not bad for the motor to run 2 maps. if anything the e85 will clean out your fuel system and gunk. Only caution is making sure you remember to be as empty as possible when switching fuels. (and actually remembering to flip the switch lol )
+2.... I agree with both the above replies. And I believe there is even a way with the proper ecu mapping software that you can just be cruising on 91 and stop to fill up with say E85 and your programing will detect the changes in octane and adjust accordingly. So you won't have to worry about being almost empty while on 91, before you fill up on E85 and then flip the switch. Though I haven't seen it with my own eyes as of yet so don't, "QUOTE" me on that.
Nice thanks for the input. My fuel pump is actually a 255 so should support it though I will need injectors and the spray switch is a good idea considering I've heard its pretty pointless. I'm also gonna get a lower intercooler pipe beforehand should I upgrade anything else?
All input is appreciated I have the four inch perrin fmic and the clutch is an act with a built tranny. I might c what diff injectors a couple shops suggest around here in Colorado
once you switch to ethanol you'll not wanna go back lol but yeah ill be double mapping it here in a week once i get my tune.. im running stock turbo, about to instal some gsc s2's w/ a walbro 255 and 1450 injectors. should be set for now, until i get my fp black installed then ill need to go to the double pumper.. good choice on switching though lol
Mikey
How's that work on a stock ECU setup?
