boost leak test: do you plug the diverter valve outlet?
Old Jul 5, 2011 | 08:03 AM
snafufx's Avatar
Finally got a chance to run a boost leak test and noticed most the air is traveling through the diverter valve output side when it hits 10ish psi. How do you all plug the actual output side of the valve to perform the test? Is there any other locations I need to plug up?
Basically I noticed while partial throttle, as soon as the turbo "whistle" begins to spool, there's actually two whistle noises. Like a higher tone before the actual turbo spool whistle kicks in. Just installed a rebuilt transfer case by shep so I know it isnt tc whine.
Old Aug 16, 2011 | 11:12 PM
bhmax's Avatar
Curious about this too. I can get the pressure above 20psi, but some air is coming from the div valve. Searching to see if this is normal or if I have a bad ix valve with only 22k miles?
Old Aug 17, 2011 | 02:09 AM
mirkendargen's Avatar
You don't plug it, because it leaking is a boost leak that you were testing for . It won't affect your metered airflow and make you run rich, but it will make your turbo work harder.
Old Aug 17, 2011 | 04:49 AM
nirvancol's Avatar
yeah thats a boost leak, you need a new dv. Tthe same thing just happened with my stock dv. It leaked around 22psi. My car is tuned to 25psi, so I got a synapse dv.
Old Aug 17, 2011 | 05:56 AM
B.J.@ToxicFab's Avatar
It should not leak at 10psi...As nirvancol said, you need a new BOV/DV & his suggestion is good, Synapse DV...I run the same one on my car and have boost leak tested it up to 25psi, held strong...
5k6
Mar 12, 2017 03:21 PM
Charlie-Y
Mitsubishi TC-SST Discussion
Oct 19, 2016 09:04 AM
Jbevoxx
Jun 8, 2016 11:44 AM
blkdrgn09
25
Aug 5, 2015 04:57 AM
19EVO91
20
Apr 8, 2012 09:27 PM
