Getting ready to take my car to buschur, any recommendations?
Old Jul 28, 2011 | 06:24 AM
Jag14916's Avatar
Hello fellow enthusiasts, i have put my first 2000 miles on my evo and its ready for a check up, while its there im going to have gauges installed, new tubing, also a new tune. I want to be able to take my car on road trips and not worry, thinking of bumping down to 19psi, and re tuning. Thoughts??
Old Jul 28, 2011 | 06:34 AM
MarylandEvo's Avatar
You have a tune from CBRD...why are you getting a retune when there should be no need
Old Jul 28, 2011 | 06:55 AM
Jag14916's Avatar
I didnt know if dropping my boost would effect my tune in a negative way.
Old Jul 28, 2011 | 06:59 AM
evo8426's Avatar
Don't drop the boost, that will not make the car more reliable. The tune is what makes or breaks the car. Hell, I ran 26psi on pump gas for a year and now running 29psi until I switch back to pump gas. I might would even turn up the boost on your car and retune
Old Jul 28, 2011 | 07:15 AM
boosted91t's Avatar
Yea your already making great power with the small list of mods on the stock 8 turbo. What are your goals besides retuning it at a lower boost pressure and making less power?
Old Jul 28, 2011 | 07:26 AM
Jag14916's Avatar
I just want to be able to drive long distances such as Ohio to virginia and to florida without such a worry, but i dont track my car, its just my summer daily driver, i dont want to put so much strain on it, but i dont really know whats to much or to little...
Old Jul 28, 2011 | 07:27 AM
05blue8's Avatar
The guys above me have said enough. A retune isn't necessary until you change up mods. You can turn down the boost without a retune, the car will run richer but it won't hurt it.
Old Jul 28, 2011 | 07:38 AM
VKEVO's Avatar
You don't have to worry about your car at all if it is already tuned. It really depends how you drive your car.
Old Jul 28, 2011 | 08:54 AM
Jaded-7's Avatar
^ agreed. lowering the boost won't matter if it's got a good tune. You only see the boost when you really get on it anyway.
Old Jul 28, 2011 | 10:01 AM
thepoint4life23's Avatar
Just ask them to not do a hard core tune you can drive it were every you want
Old Jul 28, 2011 | 10:19 AM
blackenedwings's Avatar
Lowering the boost to 19 psi is silly. I road race my stock block at 26+ psi. If CBRD tuned the car already you should not need another tune. They do great work there. Chad isn't going to give you a tune that will blow up driving it around.
Old Jul 28, 2011 | 10:33 AM
mirkendargen's Avatar
You can lower the boost while taking long trips with your right foot, and not fiddle with the tune.
Old Jul 28, 2011 | 10:39 AM
TommiM's Avatar
When your cruising on the highway you shouldnt be boosting much, or very little. If your a digital driver with the gas pedal either conmpletely floored or not at all then I would look at your driving style. Just because your evo is tuned at 23 psi, doesnt mean you have to boost 23 psi between every red light.
Old Jul 28, 2011 | 11:37 AM
SmurfZilla's Avatar
you can run 21 pounds if your a scaredy cat.
Old Jul 28, 2011 | 11:41 AM
gkania's Avatar
I'd keep your car with CBRD
