Headlights on - dash/gauges not illuminated
Old Oct 9, 2011 | 06:29 AM
berkel's Avatar
Hi all,
Quick question, just got the car (2003 Evo VIII) back after it had been in the body shop for several months. Went out for a drive last night and realized that when the headlights are on, dash/gauges do not illuminate. Makes is kind of hard to see how fast I'm going lol.
When the headlights are off, the dash/gauges are illuminated. Something must be wired backwards, but can anyone help on where to look? Could it be a fuse or maybe the wiring to the gauge dimmer switch?
Thanks for any input...
Old Oct 9, 2011 | 06:48 AM
gsrboi80's Avatar
Did you try moving the dial up for brightness????
Gauges will be illuminated when HL's are off thats normal
Old Oct 9, 2011 | 07:12 AM
berkel's Avatar
Hi,
Heh, yes I did try the dial . I thought it was normal for gauges to be illuminated when hl are off, but it's been awhile since I've driven the car so I wasn't sure... So when hl turn on, gauges go dark and dial doesn't work. I wouldn't think it's a fuse since they illuminate when the hl are off, maybe a wire somewhere?
Thoughts? I haven't looked under the dash yet, but was hoping for guidance on where to check...
Thanks.
Old Oct 9, 2011 | 01:47 PM
barneyb's Avatar
Check that your tail lights are working.
Old Oct 9, 2011 | 03:09 PM
berkel's Avatar
Hey all, there were two plugs behind the headlight height and dimmer dials that were disconnected. hooked them both up and everything works again. I think the body shop disconnected them when shutting my alarm off.
All good now..
