ran at the evo vs sti shootout at etown yest!
Old Oct 16, 2011 | 09:51 AM
vinNybXx's Avatar
Ran yesterday it was very windy over there, my launches suckkk my 2 step is set at around 6900rpm's cant build boost only 0.4 bar of boost!!! the car just takes off spins slightly then bogs bad as you can see in the video!! any ideas how to fix that? I know with a good lauch ill be in mid to low 11's with that trap speed.
In the third pic the 2 step was lowered to 6k and just made it worst, and only build 3psi on the 2 step!!
Mods:
Hta3582r .82ar with mynes tubualr t3 manifold on 28psi
tial 44mm wastegate
hks 272 cams
ets intake
arp headstuds
act hd 6 puck clutch
shep transfer case
ets 3.5 intercooler
walbro 255
ets licp v2
id 1000cc injectors
ets uicp
greddy ti exhaust
hallman boost controller
(I have more just thinking off the top of my head)
stock:
throttle body
intake manifold
head
block
full interior with ac everything from factory
etc
anyways staight 93 pump only 450whp 339 torque28psi
http://www.youtube.com/watch?v=e-Kwjhe8NyU
Old Oct 16, 2011 | 10:05 AM
Raptord's Avatar
Looks like you need to slip the clutch a bit more to keep it from bogging. Who tuned it? Running Tephra v7 with launch maps should get you to build more boost off the line.
Old Oct 16, 2011 | 10:17 AM
AWD96's Avatar
You need the driver mod badly. Set the launch RPM to 6k and release the clutch slower. Instead of dropping it and your tires chirp because the clutch is instantly grabbing and then you bog because it doesn't have the holding power to spin the tires. That's an ACT for you. Your also shifting very slow. I go 93mph in the 1/8 and run an 11.5@118 on a stock turbo. A 35r on pump should still trap high 120s. You pick up almost 30mph in the back half so the turbo is cooken you just need to match the power with driving skill. Let the other car launch first so its not as hectic and then practice your technique.
Old Oct 16, 2011 | 10:20 AM
vinNybXx's Avatar
ivey tuned it this week
Old Oct 16, 2011 | 10:23 AM
vinNybXx's Avatar
your right i did just dump it i didnt want to burn it this was my first time at the track
and your right about the act clutch i cant shift to fast otherwize i cant get it into gear -__-
Old Oct 17, 2011 | 06:51 AM
vinNybXx's Avatar
What do you think ill run with a good launch with that trap?
Old Oct 17, 2011 | 08:50 AM
ILoveAWD's Avatar
nice run
Old Oct 17, 2011 | 09:05 AM
s.lamoureux's Avatar
your set up is not far off from mine, im at like 11.2 right now with a six speed so you should def be low 11s
Old Oct 17, 2011 | 07:20 PM
Playap07's Avatar
Veteran: Air Force
dropping that clutch huh. no bueno sir no bueno! Keep practicing tho. Im one to talk because i cant launch mine perfectly either. i keep doing the same thing so i practice here an there at times.
dbrown989
02-03 Lancer Show / Shine
55
Apr 22, 2017 10:58 PM
rEvolutiondan
Sep 14, 2013 03:43 PM
DynoDude55
For Sale - Cars For Sale
35
Aug 20, 2013 12:12 PM
Evokid03
Oct 17, 2009 04:29 PM
blue by ray
100
Jul 20, 2007 01:02 PM
