300$ to spend..
Old Oct 18, 2011 | 05:26 PM
  #31
evo101395's Avatar
Originally Posted by kanyonkid
if u have a lifetime membership at the track why dont u do some suspension mods.. Whats the point in having a 36ohp car that cant turn nor stop
i only have 300 dollars..
Old Oct 18, 2011 | 05:28 PM
  #32
kanyonkid's Avatar
OK. Rear sway bar, rear trailing arm bushings, alignment... Best 300 bux u can possibly spend
Old Oct 18, 2011 | 06:14 PM
  #33
seanr8368's Avatar
bit much
I've got 300 bucks....mods on the car now are megan ti catback exhaust, test pipe, boost controller, air intake, 255 walbro fuel pump, and a few visual mods..puts out 360 whp. So what should i get with 300 bucks?
Doesnt that seem like alot of hp for those mods? i got way more and not even close to that
Old Oct 18, 2011 | 06:18 PM
  #34
nemsin's Avatar
Get a $300 detail.
Old Oct 18, 2011 | 06:41 PM
  #35
Pal215's Avatar
If your looking along the lines of visual appeal, you can get a carbon fiber VG or Mynes hood dampeners so you don't have to use the stupid hood prop. You can also buy a manifold heat shield or a radiator shroud.
Old Oct 18, 2011 | 07:08 PM
  #36
sujinX's Avatar
well, not much u can do with 300 then. u should save it and get a TRE max lock. 450 for the service. u dont need a rear sway bar, the stock is sufficient. only get it for fine tuning.
are u on stock suspension? if so, upgrade the springs. i think thats around 300 depending.
Old Oct 18, 2011 | 07:15 PM
  #37
Pal215's Avatar
I agree 100%! If you are on stock suspension get these: http://www.google.com/products/catal...ed=0CCEQ8wIwAQ
It will make the biggest possible difference for around 300 bucks.
Old Oct 18, 2011 | 08:06 PM
  #38
Broham's Avatar
This thread is like saying what oil should i use during an oil change. I say save your money
Old Oct 18, 2011 | 08:24 PM
  #39
whitebreadd's Avatar
Couldnt he set up ecuflash for $300?
Old Oct 18, 2011 | 08:39 PM
  #40
Tuxevo's Avatar
Why not go to the F/S section and see what catches your eye? Or look at the "modding your Evo, $100 at a time" thread.
Old Oct 18, 2011 | 09:59 PM
  #41
mikeywick821's Avatar
you can not get a visual mod and engine mod for $300.
just save and don't rush.
do it right the first time.
just my .02
Old Oct 19, 2011 | 06:24 AM
  #42
Pssst's Avatar
Originally Posted by tsidrift1
Only Megan part that I know is sketchy is the exhaust mani. Im pretty sure the o2 housing and def the exhaust has been a pretty good, budget part.
My Megan race manifold has been on my car for over 40k miles and zero problems..
Old Oct 19, 2011 | 08:56 AM
  #43
cmspaz's Avatar
Injectors and go E85.
Single best mod you can do, everyone else in here is just making noise.
Old Oct 19, 2011 | 09:09 AM
  #44
pacent's Avatar
If I had a lifetime membership at a track, I'd need at least a $3000 budget a month for R comps and track pads alone.
360whp does sound sketchy for how few mods this guy has. I'm at 375whp on pump gas, and my IX is cammed.
Old Oct 20, 2011 | 08:23 AM
  #45
maybe 360 crank hp lol not whp?
