Evo 4 Maintenance
Old Oct 23, 2011 | 12:51 PM
ynnus's Avatar
Evo 4 Maintenance
Hello evolutionm.net I am a new owner of a lancer evolution iv.
I am a fan of Amsoil motor oil but this time I want to switch over everything to Amsoil. I also plan to get an amsoil cone filter to replace my HKS mushroom filter.
The problem is there is no EVO IV in the vehicle list on their website so I put in a 2003 lancer turbo I assume its an EVO 8 in this link.
http://www.amsoil.com/mygarage/Produ...BISHI+LANCER+F
I was hoping some knowledgeable members or amsoil users could advise me on this list of products I made for everything. I also compared the fluids to the list of fluids used in the evo 4-10 in the pdf I attached.
Would the oil filter for the EVO 8 be the same as as EVO 4? I want to run the larger oil filter but not sure which one it is.
How much brake/clutch fluid do I need?
engine oil 5.1L
SAE 5W-30 Signature Series 100% Synthetic Motor Oil
coolant 6.0L
Propylene Glycol Antifreeze and Engine Coolant
brake/clutch
Series 500 High-Performance DOT 3 Brake Fluid
maual transmission 2.8L
Manual Transmission & Transaxle Gear Lube 75W-90
transfer box 0.62L
Severe Gear 75W-90
differential 0.41L
Severe Gear 75W-90
torque transfer mechanism 0.70L
Synthetic Multi-Vehicle Automatic Transmission Fluid
AYC hydraulic piping fluid 1.0L
power steering aprox. 1L
Synthetic Universal Power Steering Fluid
oil filter
AMSOIL Ea Oil Filters EA15K46-EA
File Type: pdf
Old Oct 23, 2011 | 01:40 PM
apagan01's Avatar
As fopr the filter question yes, as long as its a 4G63 engine EAO15K46 is the filter you need.
A for the other engine oil i think the previouse generations required a thicker oil like a 15W50 or 15W40.
tcase and rear diff use severegear 75W90
tranny use MTG GL4 75W90
all the other fluids and quantities are correct.
let me know i can get them shipped to Canada at a better price than most can
Old Oct 23, 2011 | 02:02 PM
ynnus's Avatar
I believe that is what I have on my list right? or maybe I'm not seeing what you're seeing.
For the oil I am going with 5w30 because the pour point is lower and the temps go below -40C for long periods of time where I am. Does anyone know if that is ok for this older EVO?
Thanks, I will let you know when I am ready to order.
Old Oct 24, 2011 | 08:45 AM
ynnus's Avatar
Also does anyone have experience using the amsoil air filters with their evo?
http://www.amsoil.com/storefront/eaau.aspx
I am looking to replace my hks with one but I seem to see most people using hks.
golgo13
445
May 26, 2025 05:37 PM
Fuego
Mitsubishi TC-SST Discussion
Oct 19, 2016 08:40 AM
kevster907
Oct 5, 2014 08:41 PM
Roen
Jan 24, 2014 05:52 AM
Clipse3GT
15
Jun 19, 2012 06:54 AM
