Adding front pipe quietens the exhaust noise???
Hi all,
I'm just lost for words here. I had catback + catdelete pipe. Then got a 3" front pipe installed today and the exhaust seems quieter??? Does this make sense??? Doesn't less noise = more restriction???
Thanks in advance
Thanks in advance
If you installed a 3" DP without a cat and you already deleted your second cat then what restriction could you have? Seems to me the exhaust note would be deeper, not necessarily quieter.
I used to have a stock 2.5" dp then got 3" dp. Well that exactly what i mean. The deep rumble i used to have with the stock 2.5" dp has quietened down with 3" dp.
Good Lord-- maybe the new pipe is made of a better gauge steel, is coated, have you wraped it? Lots of things can lead to noise being reduced..that doesnt equate to more restriction all the time.
NVH is controlled mostly through 3 things I believe.
1. Absorbtion
2. Direction
3. Restriction
So it is certaily possible to have no flow degregation and make it quiter
smevox
Jan 14, 2019 07:13 AM
LanEvo9MR
32
Jun 21, 2012 10:27 AM
