How much for a 60k tune up for Evo IX usually cost? PLEASE HELP! =(
I've been asking different shops and they all gave me a different prices and different recommendation on what I should change. Can someone have a look in the list and tell me what to remove and what to add to the tune up? I don't need anything very performance, I just need it tune up the basic way. $1,700 is a bit crazy to me for a tune up, plus I don't even know how much is a reasonable market price for tune up for the Evo IX... I'm really out of budget....
Below is an estimate from FFTec in Hayward quoted for me.
The list of parts looks about right. You could probably get by without the spark plug wires, and alternator belt. Then again, those 2 parts are like $100 so I'd go ahead and do it. A huge part of that bill is labor, so if you did the work yourself you save a bit. Also, we've actually got an HKS timing belt and balance belt in stock that are overstock. They're on our eBay store right now.
Also, you could knock off the diff/t-case fluid change and do that yourself in a few weeks.
Seems about right, its an expensive job, timing belt jobs are usually 600+ in parts and usually over $1000 total including labor. its a good bit of work. the spark plugs and trans fluid and diff fluids you might as well do especially if you havent done them yet, supposed to be changed every 15k on the trans and diff, everyone has there personal choice i run redline. not saying thats the best thats just my personal opinion and what my car seems to like. you could knock off the plugs and trans and save some money and do them later, but depending on funds id say just do it all at once and just get it done with. Might as well change your engine oil and filter to while your at it.
I did the engine oils recently. That's all I can do, maybe I can try doing the spark plugs myself too if it's easy enough for a mechanic noob like me. I just want to know like what exactly has to be change. I can't find a manufacture list, instead I can only find what people mentioned what they want to change.
You can do the spark plugs if you have the right tools, ie spark plug socket, extension, rachets, etc. if you do it takes 15minutes at most. very simple job. just be careful when putting them back in that you start threading them by hand and then finsih tightenting with rachet. you dont want to strip the threads here or ull being pulling the head. pretty easy. pm if you have any questions. i just did my timing belt recently and work at a shop. feel free to ask questions.
