Please help!!! evo problem...
Old Nov 16, 2011 | 03:17 PM
eddievo8's Avatar
i was entering the freeway today and i had to gun in a little. i was in first gear when suddenly my car just started making this whining noise and lost all power... no smoke came out from my exhaust...engine oil is fine..no smell either.. i just lost all power. my car just drives like a regular car without *****...while it makes that noise i checked intercooler piping and hoses//
.everything is connected..any ideas on what can this be??
Old Nov 16, 2011 | 03:58 PM
llDemonll's Avatar
there is a difference between "lost all power" and "car won't boost"; sounds like the car won't boost, yea?
Old Nov 16, 2011 | 04:02 PM
eddievo8's Avatar
mmm... i will say so..
eddievo8's Avatar
i just checked the turbo for shaft play...normal...
Old Nov 16, 2011 | 05:07 PM
clubEVO93's Avatar
So the car wont boost. What happens when you get it up around 3500rpms or higher? what does your boost gauge read?
Old Nov 16, 2011 | 05:16 PM
ChanseEvo8's Avatar
Registered User
Check your vacuum lines incase one of them pop off. Especially the one under you TB where it's connected to your egr.
Old Nov 16, 2011 | 05:19 PM
eddievo8's Avatar
I checked all the hoses I can see...everything is connected . I don't have a boost gauge. Don't have a boost control either. Just basic bolt ons
Old Nov 16, 2011 | 05:21 PM
eddievo8's Avatar
Is just drives like any other car through out all rpms
Old Nov 16, 2011 | 05:24 PM
clubEVO93's Avatar
So no waste gate pressure? I would check to make sure your c-clip hasnt broken off. It happened to me. And then I would start rechecking every turbo related line. And I think it would be wise to invest in a boost gauge and a wideband.... Just my .02
Old Nov 16, 2011 | 05:27 PM
eddievo8's Avatar
Yes it would be wise...I'm just super broke that's why im ****ting it...
Old Nov 16, 2011 | 05:28 PM
eddievo8's Avatar
What do you mean by c-clip btw?
Old Nov 16, 2011 | 05:33 PM
clubEVO93's Avatar
Please help!!! evo problem...-evo.jpg Just click on the picture to enlarge. Where the wastegate connects. There is a clip the hold it. And when mine broke it would boost.It was just a normal lancer
Old Nov 16, 2011 | 05:37 PM
eddievo8's Avatar
Thanks...I just checked it and its connected...not broken..
Old Nov 16, 2011 | 05:41 PM
clubEVO93's Avatar
Did you throw any codes?
Old Nov 16, 2011 | 05:42 PM
prowakeskater's Avatar
did you check your MAF plug? does it idle weird?
