need some quick opinions
Old Nov 28, 2011 | 08:50 PM
Blue_05EVO's Avatar
So my evo is my DD runs fine gets about 24-25 mpg.....however when I am driving normal and shifting around 29-3000 rpm it seems like it falls on its face.....and even when I do a mid rpm range pull to redline..
.it kinda feels (off) weird....like trying to run while holding your breath .....u can do it but not as well...
plugs are gapped right....kn drop in filter is clean....any other suggestions
Old Nov 28, 2011 | 09:56 PM
BenJ's Avatar
Do you have a boost or afr gauge? If so, what do they read when the problems occur, as well as at idle and wot?
Old Nov 28, 2011 | 10:21 PM
Blue_05EVO's Avatar
Boost spikes to 23-24 and settles around 17-18 in 3rd....idle exactly previous owner put a gauge that only goes to 20psi and tuned it to 23 ! But I may build 1-4 psi when im shift around 29-3rpm
Old Nov 28, 2011 | 10:42 PM
MileHighX's Avatar
Does it do this at partial throttle or wot?
Old Nov 28, 2011 | 11:00 PM
Blue_05EVO's Avatar
3 rd gear wot.......1-4 psi just cruising shifting at 29-3000
Ps looking to trade my autometer boost gauge for one with higher psi.....but that beside the point
Old Nov 28, 2011 | 11:13 PM
Revo15's Avatar
Sounds like a small boost leak maybe your tb shaft seal,foul plug or injector!!! do a boost leak test it may also be your overboosting!
Old Nov 28, 2011 | 11:14 PM
Revo15's Avatar
do u have a mbc?
Old Nov 28, 2011 | 11:24 PM
Blue_05EVO's Avatar
Yes I have a hallmam nbc, forge db and full open turbo back exhaust.....the plugs look fine....I have 18-19 vaccum when at idle and warm.....so I havmt done a boost leak test.....I thought about overboosting especially only by. 1 or 2 psi.....bit I didn't think it would make it fall on its face....I would think to much fuel would cause more of that....
Old Nov 29, 2011 | 12:55 AM
Blue_05EVO's Avatar
Bump
Old Nov 29, 2011 | 04:16 AM
Blue_05EVO's Avatar
Am I correct on to much fuel....or can over boost cause it
Old Nov 29, 2011 | 10:01 PM
Blue_05EVO's Avatar
Update!! Turned boost down felt loss of power even more at 20psi........so back to idk.....what about my above question?
Old Nov 30, 2011 | 12:12 AM
ryun84's Avatar
Are you sure it's not just your body becoming accustomed to the power? Drive a 20 year old beater for about a month and maybe the problem will go away?
Old Nov 30, 2011 | 12:52 AM
Blue_05EVO's Avatar
Lol im coming from 7 dsm's .....3 built by me....I dunno if maybe the heavier car, or bigger body makes it feel like it but I feel like my 14b swapped gst. Was faster and had more pull
Old Nov 30, 2011 | 10:07 AM
CodyEvo's Avatar
Best bet would be to have a wideband to see your a/f ratios. Being a tad rich could cause a slight overboost. But im not sure being rich enough to fall on it face would cause an overboost
Old Nov 30, 2011 | 12:54 PM
Blue_05EVO's Avatar
Well until I can get past christmas to get a wideband should I set boost in 3 wot at 20psi or slightly. Over around 23psi where the tune was set supposedly
