Sea Foam
I've used this stuff for awhile now and i have to say it cleans the hell right out of your whole system i usually do all three and put some in my oil fuel and run a little through a vacuum line! only after an oil change or right before it needs it to do a little clean up!! for $8 a can it really is amazing stuff!!!
Here's a how to video if anyone is interested in seafoaming your evo. I've done this 2nd so far and it worked great.
I've always seafoam the car, drive it hard for a few mins, then do an oil change right after.
though you may have to reconnect the hose to get the car started back up. Or you can just let it marinate for 10 minutes or whatever the instructions say and then go driving.
If it stalls, reconnect the hose and start it back up. Just be smart about it. Do a little at a time, you'll know when your car is about to stall.
Also it helps if you have a 2nd person in the car to keep the revs up.
Or you could just feather the throttle with your other hand, I mean it's right there in the same general area.
dk3Jdefje1X
Jan 12, 2017 07:02 PM
Joe's Evo X
Oct 9, 2014 10:33 PM
