Sea Foam
Old Dec 8, 2011 | 03:10 PM
pacent's Avatar
Fair warning, your car smokes like crazy when you're running this stuff
http://www.youtube.com/watch?v=mgTG6nJTciI
Old Dec 8, 2011 | 03:19 PM
Ramen_Noodle's Avatar
That's the fun part! It's also a good reason to do it at night so you don't confuse/anger your neighbors. If your car has a lot of carbon build up, it WILL smoke A LOT.
Old Dec 8, 2011 | 03:20 PM
DJAfterShok's Avatar
Very true! I did it in my DC2 integra a lonngggg time ago. I smoked like it was on fire! I went to an Ace hardware parking lot around midnight to do it until it cleared out lol
Old Dec 8, 2011 | 03:28 PM
Get Rad's Avatar
I have been wanting to throw this is my Evo since I am almost at 50k. I think I will give it a shot.
Old Dec 8, 2011 | 06:27 PM
5speedwtneed's Avatar
How to use seafoam... My .02 and not really 100% factual. Before this car I had a 2007 MINI cooper S which is direct injection so the valves never have fuel on them and gunk up. So I sea foamed my car every other oil change. You're technically supposed to do 1/3 bottle into tank 1/3 into oil and 1/3 in PCV valve. I only did the PCV valve. Use 1/3 of it there and do it so slowly that it takes you 5 minutes. And after you have poured that drive the **** out of your car down the road... (seriously, you need to flush the system). And don't pour into your vacuum lines unless it's RUNNING (hope that was obvious) lol. I agree with the in oil right before change. Like one day or two before. And running in fuel probably isn't a problem. If running it hard or racing I would probably suggest not since it might affect the tune a weeeee bit lol. Cheers
Edit: some people suggest changing plugs after using seafoam. 20k miles later (3 seafoam treatments) racking up to 70k on the Cooper S, I had never a problem. Still were original plugs and they are supposed to be changed at 60k anyway.
Old Dec 8, 2011 | 06:46 PM
dillonb's Avatar
i thought you shouldnt run this in a turbo'd car but i guess it seems fine?
Old Dec 8, 2011 | 07:03 PM
BoostINurI's Avatar
Never did the evo...did it a bunch to my dsm's back in the day...insane smoke out!!!
If it takes the e85 gunk off the injectors i might be down for a little test.
Old Dec 8, 2011 | 07:09 PM
twabtoxer's Avatar
so you can use seafoam while you are on e85?
Old Dec 8, 2011 | 07:21 PM
WolfsFang's Avatar
Originally Posted by Ramen_Noodle
You can buy it in liquid or aeresol. Using the aeresol is the easiest way to feed the vacuum line and liquid for the gas tank or oil.
for the aeresol where/what is the best hose to spray into?
Old Dec 8, 2011 | 07:44 PM
sushii's Avatar
This seems cool. But I thought your not supposed to use stuff like this on turbo cars..?
Old Dec 8, 2011 | 07:53 PM
Playap07's Avatar
Veteran: Air Force
I seafoam my civic every 10,000 miles. I put it in the gas, oil and brake booster line and it would clean out everything. It was pretty good at what it does and it made my civic sound live a subaru for a lil haha. Excelent product you can get at any auto store like advance auto or Napa.
I never did my Evo yet since i havent put alot of miles on it since i got her. the next oil change and spark change im going to Seafoam her sexy ***!
Old Dec 8, 2011 | 07:55 PM
BoostBuddyGSX's Avatar
Marvel Mystery Oil < Seafoam
Old Dec 8, 2011 | 08:07 PM
gymnasty's Avatar
I just did my 60k maintenance on my 9 about two weeks ago. Can I still try this Sea foam thing? If yes which is the proper/correct way to do it? Pour it in the fuel tank, in the oil or in the vacuum line?
Old Dec 8, 2011 | 08:19 PM
mexfizzle's Avatar
so can we use this on e85 gas or no ?
Old Dec 8, 2011 | 09:03 PM
DubsE46's Avatar
Sea foam worked wonders in my car, made it run smooth & improved mpg's
Used some in the gas tank, vac line and oil
