E85 800-1000hp Fuel System Setups
Old Dec 21, 2011, 03:53 PM
  #61
TurboTravis's Avatar
Originally Posted by Freddie@Spec-Ops
Travis, im not... I don't plan on doing anything else with my car and I am not where close to being maxed out... I was just asking dave since he has done it and id he says IDC dropped a bit that tells me it worked...
And this is the time where if I don't have anything good to say, I don't say anything at all
Old Dec 21, 2011, 07:33 PM
  #62
Chu's Mom's Avatar
i'm still digging a fuel cell setup....haha.
Old Dec 22, 2011, 10:56 AM
  #63
Spec-Ops1's Avatar
Yet you did... I try to be courtious to everyone, so please don't patronize me...
Old Dec 22, 2011, 11:04 AM
  #64
David Buschur's Avatar
Then if you are digging a fuel cell, that is your solution, go for it!
Old Dec 28, 2011, 05:46 AM
  #65
Chu's Mom's Avatar
Bump for anyone else with a big fuel setup. I'm still on the fence. There's more than one way to skin a cat
Old Jun 15, 2012, 05:23 AM
  #66
Creamo3's Avatar
Bringing this one back from the dead; I'm currently running Buschur DP with modded 255's, FIC 2150's, Fuel Lab mini-FPR, and Perrin fuel rail. My IDC's are in the mid-90's and I want to make sure I buy the right parts to upgrade the fuel feed to -6.
- Do I use 3/8" hose to go from the fuel filter outlet to the rail?
- Best type of hose to use / place to buy? (Summit?)
- Where to get a reliable clamp for the fuel filter outlet?
- I'll probably just get the fittings for the fuel rail from Summit as well
Old Jun 15, 2012, 06:12 AM
  #67
Dragracer187's Avatar
I am in the middle of making my fuel setup. I have a buschur dp with AN fittings, I will use 2x -6 to a NOS Y piece to go from 2x -6 to 1x -8, fuelab filter after the Y piece and -8 line to the fuelrail. -6 return from fuelrail to a mini fuelab fpr and, fuelab sells a fpr with only one inlet and one outlet, no need to blank anything off, not sure why everyone buys the 3 port and blanks one port off. From the FPR it goes to -6 to the OEM feedline, I want to use that as the return, there is a adapter that fits the OEM feedline in the enginebay to AN fitting. AMS uses this for their replacement feedline. Only need to source that adapter. I am talking about this one:
If anyone know where to get it, cause AMS wont sell it seperate.
Old Jun 15, 2012, 09:52 AM
  #68
Liqquid's Avatar
Originally Posted by n2oiroc
thats another thing i was paranoid about. i actually bought a check valve and pressure switch to wire up an in dash led to let me know that the 2nd pump is running. im switching to a proefi ecu with a fuel pressure and oil pressure sensor so if a pump doesnt turn on or loses flow, it can shut it down. same if the oil pump dies, it will see low pressure and go into limp mode to keep it in one piece.
I'm running that and the fuel pressure sensor as well, it works. I didn't have my pumps modded for high pressure a few years back and the fpr detected the pressure was fluttering when it got over 70 or so, and turned on a cut.
Old Jun 15, 2012, 03:55 PM
  #69
jessmanEVO's Avatar
^^^ exactly what Im running along with 2150s.
Old Jun 15, 2012, 06:02 PM
  #70
Originally Posted by Helen318
if you are going to use a cell and run the car on the street, dual bosch 044's. im keeping the stock tank and running dual 044's with a surge tank. all the big single pumps (even weldon) will eventually fail if you use them continous duty. im not a fan of walbros, made in china junk. 044's have proven to flow well and last forever
For reference, Walbro's are MADE IN THE USA. There are other things wrong in your post but I'll just cover that one.
Old Jun 15, 2012, 06:07 PM
  #71
batty200's Avatar
Agreed. Also a PWM controller on a big pump will greatly enhance pump life. Another option is a mechanical that will be very reliable and when the engine stops so does the fuel.
Old Jun 15, 2012, 06:47 PM
  #72
n2oiroc's Avatar
another problem with a big single is the fuel gets really hot from the continuous pumping. and as stated, not a single one will last. check the supra forums for proof. the 044 is proven reliable, you can pump sand with it and it will keep going.
Old Oct 7, 2012, 10:21 AM
  #73
LGshow19's Avatar
Ive came to a conclusion to run twin 044s with 3/8 steel line from the filter to the fuel rail. I dont see why this setup can push out 800whp+ on a Mustang Dyno.
Old Mar 19, 2017, 08:40 AM
  #74
nedor94's Avatar
magnus
Originally Posted by Chu's Mom
Anyone have any experience with the Magnus Mechanical Fuel Pump Bracket and Aeromotive Fuel Pump?
​​​​​​i would also want some opinion on this setup, looking to buying this just bc no one is running it on streets in PR is it any good for 800hp on sunoco or Vp?
Driv200
Dec 3, 2017 07:21 AM
Voltexed
Jan 29, 2017 08:27 PM
razorlab
Dec 6, 2016 08:45 PM
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
Anubis18
Nov 28, 2016 10:18 AM
Quick Reply: E85 800-1000hp Fuel System Setups
