Engine damper
Old Dec 28, 2011 | 04:14 PM
dastallion951's Avatar
thats weird man, mine shifts at 8k, all day for about the past 35k no problem. If your having issues with shifting into 2nd,you mightve either jacked up the synchro in the trans a bit, or, replace your underhood shiftcable bushings, should help some.
Old Dec 28, 2011 | 05:59 PM
5speedwtneed's Avatar
I mean it's not like it's really a problem. It's just not easy enough for me to make it perfect with ease every single time.
Old Dec 28, 2011 | 06:04 PM
then why complain if its not really a problem?? tryin to up your post count or something?? it should shift easily into each gear unless theres a mechanical issue of some type.
Old Dec 30, 2011 | 05:54 PM
D Grade's Avatar
What clutch are you using? Single disk clutches are known to not like high RPM power shifting. Might be time for a twin disk. Or you can start by installing a stainless braided line and removing the restrictor from the slave cylinder. That'll give you a reason to refill and rebleed the master as well. All of which should help, and if it doesnt then you know it's time for another clutch.
Old Dec 31, 2011 | 06:21 AM
Single disk exedy stage 2. Car came with it. And also already has a SS clutch line.
This clutch shutters like crazy on take off. I'm not a fan of it. But it launches very well and holds well. Just low RPM take off is terrible. I'm gonna ride it out for another year then get a exedy twin clutch.
Old Dec 31, 2011 | 06:54 AM
rongdoer's Avatar
I had high rpm lockout and I got underhood bushings, then an ingalls damper...then a front motor mount and it was fixed. It vibrates a little, but it just makes the car feel more alive.
TxFAkuma
Feb 4, 2016 05:40 PM
Jsiebert
Sep 9, 2015 08:16 AM
FroZenEvo666888
Jan 23, 2014 07:08 PM
MaxRalliArt
Jul 10, 2012 05:03 PM
jameswwt
31
Aug 4, 2011 01:00 PM
